Old 05-25-2010, 02:26 PM   #1
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
Originally Posted by krusty View Post
The dry residue left by the water pump is not from a faulty water pump it has to do with the super long life coolant Toyota uses. It appears that the coolant can cause this condition from time to time and is considered normal.
YEAH, it comes from the spot down by the headlight blinker fluid....
FYI: almost ALL of toyota's water pumps are leaking. from camry's to our yaris we see at least 4/5 a day.....
Old 07-02-2010, 06:22 PM   #2
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Headlight blinker fluid?????
frog13 is offline   Reply With Quote
Old 07-02-2010, 06:28 PM   #3
frog13
Tw200--excellent!
Salt water/salt in the air doesn't help matters any.............vinegar kills mold and or change your A/C evaperator filter.
Old 08-18-2010, 05:01 PM   #4
wooverstone8
wooverstone8's Avatar
Mine went out yesterday with only 16K miles on it. I took my Yaris to the dealership twice and they assured me that there wasn't anything wrong. They will not to able to fix until Monday...
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
