If you remove the passenger seat completely, you can do either of two things to allow the SRS system to remain happy, and hence be able to pop the driver's side airbag (and curtain airbags if so equipped):
1. Leave everything connected: Remove the passenger seat, disassemble it to remove the 4 passenger occupancy sensors (which connect the main part of the seat to the frame) and the wiring between them and the passenger occupancy ECU (the little black box mounted the bottom of the passenger seat). You would then tuck all of that someplace (under the center console for example). You would also need to leave the passenger seatbelt latch internals connected (but, they too can be tucked under the console). 2. Leave just the passenger occupancy ECU, and use my Passenger Occupancy Sensor Bypass module. To avoid disassembling the seat, and to save a bit of space/weight, you can replace the four sensors and their cabling with my module. It is intended to allow the passenger airbag to still be used, when the passenger seat is replaced, but basically it takes the place of the sensors and gives you a switch that tells it to arm or disarm the passenger airbag. |
#2 | |
Prius - Yes. XB not yet (the XB uses a very different setup and I haven't had my hands on one yet to develop the solution for it).
#5 | |
![]() Drives: 2004 Echo HB 5-door Join Date: May 2014
I want to remove the pax seat in my 2004 Echo hatch to make a 600km roadtrip on Monday to pick up some parts, and I'd rather have the airbags working for the duration. I'm thinking of going to the scrapyard and picking up either a seat (35$) and remove the back or just rip out the sensor (9$). Are you aware if the sensors for Echos are compatible throughout all years? I remember the bit that goes inside the seat looking rather flimsy. How durable are these thing? I was thinking of leaving the lot dangling down on the floor under my heavy engine parts and plastic bins. |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Clazzio Seat Cover DIY Install | PETERPOOP | DIY / Maintenance / Service | 31 | 09-10-2010 03:30 PM |
| Complete Racing Seat Install Guide | advocate | DIY / Maintenance / Service | 7 | 11-25-2009 02:26 AM |
| Anyone know how the passenger seat detection system works? | rage2 | DIY / Maintenance / Service | 5 | 05-12-2007 07:22 PM |
