Drives: 2007 Toyota Yaris 4dr 5speed Join Date: May 2010
Increasing Horsepower: What Should I Add To My Yaris?
I have an 07 Yaris 5speed and was wondering what I could add to it to increase the HP. I've heard iridium spark plugs and better intakes and stuff but has anyone made any mods on theirs to increase HP? If you know of anything that has helped you let me know. Thanks!
1zz throttle body if you can make it work
NST underdrive crank pulley. intake header exhaust |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
I concur with the above statement.....
And whether or not I get flamed for saying it -- use the search feature first, there is a wealth of knowledge already on here that will answer your question completely, starting with the "Performance Primer".
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
Modded Moderator
Weight reduction helps too.
The Last Baron
Drives: 09 Polar White HB Join Date: Jun 2009
i think the spark plugs should be addressed. arent the iridium plugs marketing trash? or is it different for this car?
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires! | UR 19mm sway | |
I never had a problem with the stock spark plugs, street and track. Someone would have to dyno test one brand/type against another to prove to me that there's a difference in power output.
intake, dc header, an exhaust thats more than just an axleback (ie from the resonator back)
with just an intake and res-back exhaust i pulled 106whp/107wtq on a dyno nst lightweight or underdrive crank pullies are nice too
![]() Drives: '08 3-Door Join Date: Apr 2010
Here are the things that made my car "feel" a whole lot better.
1. NST pulleys (very nice throttle response difference) 2. DCSport header (helped smooth out the power across the band and much nicer at the high end) 3. Modified air-box (most people do cold air intakes, I like to cut stuff, so I modded the box and used a K&N stock sized filter. This gave me +2mpg and a bit more low end power) 4. Believe it or not, setting up a second ground from the battery to the ECU seemed to really smooth things out all through the mid-high rpm range. Have fun with your upgrades!! |
XBL: Jeemee Ghost
_________________________________________________ Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers |
Slowy getting there
The Yaris comes with Iridiums stock...
You are all wrong. Stickers. That is all.
spinners?
wing. check.
stickers. check. ooh, spinners. I don't have those yet, thanks
Fuzzy dice hanging from the rear view mirror & a flux capacitor
Modded Moderator
har har.
Paint stuff yellow. +10hp for yellow stickers, lol Turbo, supercharger, nitrous, lightweight wheels/tires. |
| Tags |
| 2007, 5speed manual, horsepower, increase, sparkplugs |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| Help sign this petition! Add the Yaris and other small cars to Forza 2 | eTiMaGo | Off-topic / Other Cars / Everything else Discussions | 24 | 08-10-2007 12:57 PM |
