Old 05-29-2010, 03:44 AM   #1
Alien Mantis
Secret Agent
Alien Mantis's Avatar
Drives: 2008 Yaris Hatch
GREAT pics and info on that Eclipse amp!
Good job.
That amp is SWEET. Plenty of settings on that sucker. You can make it do exactly what you want it to do.
Set the MONO off on both front and rear.
Set the BASS BOOST to 0 on both front and rear.
Use HPF on both front and rear.
Set the front crossover freq to around 150hz. ( as a close starting point )
Set the rear crossover freq to around 100hz. ( as a close starting point )
Adjust your gains according to your RCA output level on your source.
( Most are around 2-4volts. )
Use that beautiful LINE OUT to connect your Mono Sub amp!
Set your Mono Sub amp crossover LPF to whatever you set your REAR crossover setting to on your 4-channel Eclipse amp.
If it's 100hz, set the mono LPF at 100hz.
( if you choose to try 80hz, then set both at 80hz and see how it sounds )
Whatever you set the REAR and the MONO sub amp LPF at, leave the FRONT crossover set at around 150hz HPF.
TEST IT OUT on your favorite music. See how it all blends together.
Tweak it from there. Small adjustments. One setting at a time.
Tweak... listen carefully..... tweak.... listen carefully.
IF you follow these instructions, you will be close, and have a good baseline.
You might be totally happy with it using these settings.
Let me know how it turns out. Good luck.
Old 05-29-2010, 03:47 AM   #2
Alien Mantis
Secret Agent
Let us know what SUB AMP you decide to buy!
( and if you still plan on going with a single 10" Bazooka tube )
Old 05-29-2010, 04:10 AM   #3
Alien Mantis
Secret Agent
ONE MORE THING....
If you wanna try something tricky, AFTER you run my baseline settings, and listen to the system for a bit.... try THIS trick:
Set your REAR HPF crossover at 80hz.
Set your Mono Sub amp LPF crossover at 100hz.
This will give you a 20hz frequency OVERLAP between 80hz and 100hz.
Your rear 6x9's AND your subwoofer will BOTH be playing that 20hz overlap range.... which might boost your total BASS output and sound nice together.
( then again, you might just end up with a nasty mid-bass spike! )
6x9's can put out some bass. It's worth testing them to see how they perform.
As with all tuning.... if you crank your volume, and you get distortion someplace, you gotta back it off with your crossover points, and your levels.
Don't put up with distortion, just because you want a little more BASS.
Back the bass off, and run it cleaner. When in doubt, always choose CLEAN.
Subs are made to play freq's below 100hz. But not all 6x9's or component sets can handle freq's in that range or lower. Most cannot. They will distort at higher volumes.
Once you set your amps, use the EQ in your DECK to fine tune the overall system to your tastes.
Old 05-29-2010, 01:00 PM   #4
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
Thanks man for all your tuning tips! I can't take the credit for the pics, I grabbed them from Crutchfields web site. The owners manual for the Eclipse has some hints, but yours are much easier to follow! I'm glad you approve of the amp and thankfully I didn't buy too "cheap"! With all your info in mind, I've been searching on Crutchfield and SonicElectronix and found that Eclipse makes a sub amp! Go figure! I think it would pair up great with the existing one.
It's an: Eclipse XA1200600W Max, XA Series Class D Monoblock Car Amplifier (XA-1200) for $129 at Sonic.
Product Features: XA Series Class D Monoblock Car Amplifier with ICE Technology
RMS Power Rating:
4 ohms: 350 watts x 1 chan.
2 ohms: 500 watts x 1 chan.
Max power output: 600 watts
MOSFET switching power supply
ICEpower class D design
Wired remote bass level control included
LED power indicators
Bass Boost (0-8 dB at 50 Hz)
Bass boost frequency selection (32-64 Hz)
Mono channel operation
Protection temperature (90 C)
Heavy duty aluminum alloy heatsink
RCA level inputs
Screw terminals
Variable low-pass filter (40-200 Hz, Linkwitz Riley 18 dB/octave)
Subsonic Filter (18 dB at 20 Hz)
CEA-2006 compliant amplifier
Frequency response: 20-20,000 Hz
Input sensitivity: 1.2V-8V
Damping Factor: 90
Dimensions: 10-1/4"L x 10-1/8"W x 2-3/8"H
4-gauge power and ground wiring is required for installation.
The subwoofer I'm looking at is either the 10" (ELB110RS for $59) or the 12" (ELW1214P for $69). Both have basically the same specs but the 12" will handle 50-300 watts where the 10" will handle 50-150 watts. I would place it in the trunk and the "footprints" are pretty close too.
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 05-29-2010, 02:56 PM   #5
Alien Mantis
Secret Agent
Yeah, I realize you didn't take the pics, I was patting you on the back for linking the photos and adding the info!
Those Eclipse amps are nice! I almost bought the XA-1200. You can't go wrong with those. Great choice.
Since you are going with such a good amp.... let me steer you towards a WAY better subwoofer than that Bazooka crap.
You just can't beat this subwoofer for value/performance. Grab one of these before they are all gone. The new models are different, and more expensive. At $99 with free shipping, this is a killer deal. And trust me, you will be much happier.
Here is the box you want for the Alpine sub:
1SV10 is the part number for the box. $29 with FREE shipping.
( they have them in black carpet, or grey carpet )
Old 05-29-2010, 03:00 PM   #6
Alien Mantis
Secret Agent
Here is the link to the subwoofer:
http://www.sonicelectronix.com/item_...+-TYPE+R-.html
You want the dual 4ohm version.
That Eclipse XA-1200 puts out 500 watts into 2ohms.
It will be a perfect match for the Alpine Type-R sub.
That sub comes with jumper leads, and a simple diagram showing you how to wire it up for 2ohms.
Old 05-29-2010, 09:16 PM   #7
Herbicidal
Herbicidal's Avatar
Thanks for the links and recommendations! I've added all 3 items to my SonicElectronix "cart", just haven't pulled the trigger yet. The free shipping is huge, but I still gotta pay about $25 in CA sales tax. I think the system will sound awesome with these additions. I may have to buy a kidney belt too!
Old 06-01-2010, 10:30 AM   #8
Herbicidal
Herbicidal's Avatar
Well I pulled the trigger, pushed the button, whipped out the credit card, whatever you want to call it on the Eclipse mono channel amp, Alpine Type R 10" sub and an enclosure. Sonic Electronix is here in California, so I should have my stuff by around Thursday. This should round out my system quite nicely! Thanks for the recommendations.
Old 06-10-2010, 11:54 AM   #9
Herbicidal
Herbicidal's Avatar
OMG!!!
I finally was able to spend about 2 hours yesterday to tune my amps. Crawling around in the back seat with Alien Mantis's instructions in one hand and a small screwdriver in the other, moving the front seats all the way forward so I could get to the adjustment screws, making adjustments, moving the seats back to the regular positions so I could sit in the drivers seat and listen, then repeat the process all over again about six more times. When I first took a look at the adjustment screws, everything on both amps was basically turned "off". While installing them, I didn't even look at the adjustment screws because I really didn't understand them. Since last Saturday, essentially I have not been using the subwoofer amp, and for another two weeks at least, the speaker amp! I was so focused on the install and keeping it all neat and tidy I just didn't even pay any attention to what position those adjustment screws where in! What a dumba$$!
HOLY FREAK'IN MOTHER OF BASS BATMAN!!!
I can't believe the difference! I still have a HUGE $hit eating grin plastered on my face this morning! AND I'm using the stock head unit! I can't imagine the sound getting better than this, let alone what a decent quality HU would do for me! WOW!!! Obviously I am very happy with the amps, speakers and subwoofer! Once I was done, I even vacuumed and washed my car. Ahhhhhhhh! My 13 year old daughter was in the house and came out to the garage to find out what the heck was going on!
LESSON: Make sure to TUNE YOUR AMP(s)!!! If you haven't done it yet, get out there and do it!!! Othewise you are just wasting your hard earned $$$'s!!!
Sub and amp for sale TEHxFALLEN V1.2 Items for Sale by private party 34 05-17-2010 09:06 AM
Custom Lift Back Hidden Sealed Woofer Box TinyGiant DIY / Maintenance / Service 42 04-15-2010 03:36 PM
Quick advice needed on unfinished amp install GreenSpeed In Car Entertainment + Electronics (audio / video / alarm) 15 01-15-2009 11:03 PM
Connect mono amp. + subwoofer to stock HU? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 10-28-2008 10:01 PM
