Old 05-29-2010, 07:07 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by RedRide View Post
I have a (02) Celica GT so, I'm in a position to make a good comparison.
First off, the yaris has more low end torque but, if you down shift the Celica, it would definately pull away from a Yaris. The Celica's 1ZZ engine is rev happy.
However, when they are both up to highway speeds (and both in 5th gear) a Yaris would probably have no problem keeping up with the Celica for the most part..
so, the 1.5L engine makes more low end torque than a 1.8L ?
the celica GT's engine rev happy? doesn't the 1zz rev to about 6300rpm? and the 1nz in the yaris rev's to 6400 or so? either way, they're within a couple hundred rpm of each other, so what makes the 1zz "rev happy" ? i've owned two cars with the 1zz and neither of them i'd consider rev happy.
Old 05-30-2010, 04:00 AM   #2
RedRide
RedRide's Avatar
Yes the Yaris engine has more low end torque than the celica 1ZZ.
In fact the The celica 2zz in the GT-S has less low end torque than the 1ZZ
The 1zz is rev happy because most of its power in in the higher RPM range. as compared to the 1nz.
Old 06-01-2010, 06:49 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
that's funny, because i compared my stock dyno graph 1zz (corolla) to my stock 1nz (xA) and imagine that, more torque from the 1.8 across the powerband....
so, since you're basing your "knowledge" on butt-dyno, i consider this conversation over.
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
Hot hatch battle - Yaris slow!!! IllusionX Photo-Video-Media Gallery 13 04-05-2009 10:07 AM
MY YARIS IS SLOW NOW????? ROCKLANDTOYOTA Performance Modifications 48 03-12-2007 09:36 PM
