Old 05-31-2010, 03:36 PM   #1
fidgell
Drives: 2006 Yaris RS 3 door
Originally Posted by adigilani View Post
Hi all
today i serviced my Toyota Yaris 1SZ-FE.
It has 39000 miles.
I changed spark plugs, oil, oil filter, pollen filter and air filter.
Used NGK spark plugs with 0.8mm gap.
Used 5W-30 oil
Used WIX WL7131 oil filter.
Used WIX airfilter.
Used WIX Pollen Filter
then went on to start the engine. the management light came on.
i figured that i have added bit too much oil so reduced it.
and then tried again and this time everything look normal.
however one thing, i think the engine is getting heated excessively. I saw bit of smoke from the cylinders. so switched off the engine instantly.
Took the Engine oil dip stick to check oil again and there was bit of steam or smoke again.
but oil seems to be topped up properly. there is no strange sound from the engine.
i do not know for the fact if something is wrong but i suspect there is. i didn't drive the car again.
can someone shed some light on all this...
please.
Try NEW instead of USED....
I should charge for the help, you cant teach this stuff!
fidgell is offline   Reply With Quote
Old 06-01-2010, 08:24 AM   #2
PhillyG
Drives: 2009 Yaris
oh dear god!!! and this is why i cant help but read the forums as often as i can! ROTFLMAO
PhillyG is offline   Reply With Quote
Old 06-01-2010, 06:14 PM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
HA!
Tags
1szfe, yaris
HID Kit High-Beam Cluster Indicator Problem Split Cosmetic Modifications (Exterior/Interior) 21 07-24-2010 05:50 PM
interior lighting problem tied with headlights 40oz DIY / Maintenance / Service 7 03-28-2010 07:52 PM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
