#1 | |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Ok so it's been almost a year since this thread was made. Anyone found / notice and negatives to doing this? Has it really made a difference in a/c efficiency? |
![]() ![]() Drives: 2008 Yaris HB Join Date: May 2009
Yep it definitely works. I used the aluminum tape over the foam and zip ties and its all still holding together nicely. Check the clearance at the back of the motor between the exhaust manifold and AC line (when the cars cool), its about an inch and half. Does that make sense? No!!
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
Pros and conns
On the Pro side it will help fuel economy because the compressor is a variable compression design as most are these days. On the con side if you were over charged and running AC on a cool day you would let liquid refrigerant into your compressor producing hydrostatic lock. When I do mine I will use aluminum tape over the insulation to reflect heat away from the insulation. That makes it way harder to melt the cheap insulation with under hood heat. The other hyper-miler tip here in Phoenix is to tint the windows. Both this insulation and window tint will cut the mileage drain AC caused here in Lucifer's waiting room. Window tint alone reduces the fan setting you have to use to wear a suit when the outside air temp on the express way says 1198 degrees F. I get 39 MPG here at 65 MPG on cruise lock. I've been watching for a trick to break 40 under the same harsh conditions. I average 42 city and highway so hyper-mile tricks between lights does work. Our winter mileage is even better than that. From my sig you can also see the other mods that allow better than EPA mileage results.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| DIY Sound Insulation Guide? | qwerty123321 | DIY / Maintenance / Service | 4 | 02-07-2009 02:56 AM |
