Old 06-01-2010, 11:18 AM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Originally Posted by Herbicidal View Post
Did I mention I'm glad to be done with the doors???
Something I really like about the doors after deadening is (and just for key-less entry) that when you lock / unlock your car with the remote, you can barely hear the noise of the system, standing next to your car...
give it a try!.
CLA 250, 4MATIC
Old 06-04-2010, 11:20 AM   #2
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
give it a try!.
Yup! You are right. Just a little 'snick, snick'.
My parts arrived yesterday! Ohhhh yaaaa! I stopped by Fry's Electronics on my way home from work and picked up an amp install kit that has 4 gauge wires for power and ground, speaker wire, remote turn on wire for the amp, plus all the little stuff that comes with the kit. I also spent $20 and bought a Monster 3-way slim line distribution block (will accept 4 gauge wire) that connects to the battery. I'll use two of the three openings for the power wires to both amps. This leaves me one for whatever floats my boat down the road. I still need to pick up a rubber grommet for the firewall as this time I think I will drill a hole next to the A/C vent drain plug hole that I used for the last power wire. Hopefully this weekend I can start running the wires, etc.
By the way, with the subwoofer enclosure, is there a "right way" to position it?
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 06-04-2010, 11:43 AM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
usually facing it toward the rear of the car will give you the most bass.
Old 06-04-2010, 12:05 PM   #4
Herbicidal
Herbicidal's Avatar
Thanks much! I'll try it that way first.
Old 06-10-2010, 02:15 PM   #5
Herbicidal
Herbicidal's Avatar
In case you haven't been following my thread about whether I need another amp to power a subwoofer, here's an update on what I've done since the new equipment arrived from Sonic Electronics. For others, this will be a repeat of the info, sorry about that. Just trying to keep some continuity. By the way, I ended up returning that Monster slim-line power block. It wasn't slim enough. With it on the positive battery post, the battery cable would not fit on correctly, so I took it back. I was able to attach the power wire for the second amp to an existing accessories 'tab' on the cable.
Here's my most recent set of pictures. As I mentioned before, the install went pretty smooth, just time consuming to do a ‘clean’ install. I used an air powered cut off wheel to remove the jack bracket under the driver’s seat and the jack does fit snugly in the spare tire compartment. I had to place a piece of 2x4 under each amp to get a level mounting spot because of a funky space between some horizontal body supports. This made it easier to connect up the wiring. I figure this allows the air to flow partially underneath and will help with the overall cooling of the amp. I’m still experimenting with placement of the subwoofer box in the trunk. Laying it flat with the sub pointing to the rear of the car takes up the most room, but standing it up and rotating it 90 degrees gives me the most space in the trunk and puts the weight closer to being over the rear axle. Anyway, I’m still playing with the positioning for sound and space maximization of the sub.
Without further ado:
Eclipse XA1200 mono channel amp.
Alpine Type R 10" sub.
Alpine Type R 10" sub, top view.
Alpine Type R 10" sub, connectors. I used the jumpers to set it up for 2 ohms.
10" vented sub enclosure from Sonic Electronix.
Alpine Type R 10" sub-in-the-box.
Preparing for surgery. That car jack mounting bracket has to go!
Where the bracket for mounting the car jack was, under the drivers seat. Needed to make room for the other amp.
The blue wire is 4 gauge for power to the subwoofer amp. The black tube is the A/C breather that vents to the outside of the firewall.
4 gauge power wires through the firewall passenger foot well red for the speaker amp, blue for the subwoofer amp.
Eclipse mono channel subwoofer amp on the left, Eclipse 4 channel amp for the speakers on the right.
Alpine Type R 10" sub in a box. I'm still trying different locations and positions so the wiring isn't finalized yet.
Old 06-10-2010, 02:20 PM   #6
Herbicidal
Herbicidal's Avatar
And my experience of "tuning" the amps, also from my 'do I need another amp...' thread:
I finally was able to spend about 2 hours yesterday to tune my amps. Crawling around in the back seat with Alien Mantis's instructions in one hand and a small screwdriver in the other, moving the front seats all the way forward so I could get to the adjustment screws, making adjustments, moving the seats back to the regular positions so I could sit in the drivers seat and listen, then repeat the process all over again about six more times. When I first took a look at the adjustment screws, everything on both amps was basically turned "off". While installing them, I didn't even look at the adjustment screws because I really didn't understand them. Since last Saturday, essentially I have not been using the subwoofer amp, and for another two weeks at least, the speaker amp! I was so focused on the install and keeping it all neat and tidy I just didn't even pay any attention to what position those adjustment screws where in! What a dumba$$!
HOLY FREAK'IN MOTHER OF BASS BATMAN!!!
I can't believe the difference! I still have a HUGE $hit eating grin plastered on my face this morning! AND I'm using the stock head unit! I can't imagine the sound getting better than this, let alone what a decent quality HU would do for me! WOW!!! Obviously I am very happy with the amps, speakers and subwoofer! Once I was done, I even vacuumed and washed my car. Ahhhhhhhh! My 13 year old daughter was in the house and came out to the garage to find out what the heck was going on!
LESSON: Make sure to TUNE YOUR AMP(s)!!! If you haven't done it yet, get out there and do it!!! Othewise you are just wasting your hard earned $$$'s!!!
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Rines 15 Yaris Sedan 2008 Marko_ec Central and South America 4 12-15-2008 03:02 PM
