Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 05-10-2011, 05:31 AM   #1
syntax
syntax's Avatar
@ rye marami na nga pala bagong member na wala pa insulation para low pressure A/C line.
i sked natin yan sa group DIY, as usual sagot ko na ang mga cable ties weheehhehe
@ rosco no problem pre' i sked natin yan sa group DIY, or sa pagbalik mo saglitin natin yan, si marky? hindi rin alam eh, mukhang natabunan ng pansit, frozen pa naman un sa pagkakaalam ko wehehehe
Old 05-10-2011, 05:53 AM   #2
syntax
syntax's Avatar
@ insan ricky meron pala naiwan dyan, pwede nyo na isked ang DIY project na yan.
Old 05-10-2011, 10:54 AM   #3
fsballesteros
Drives: Yaris Y 2010
Send a message via Yahoo to fsballesteros
ako wala rin..
aka. ka freddie
fsballesteros is offline   Reply With Quote
Old 05-10-2011, 12:05 PM   #4
fgorospe76
"i R i S H"
fgorospe76's Avatar
Drives: Toyota Yaris 2010
Ako tinira ko lang mag-isa yan...total cost SR12 plus gasgas sa daliri hehehe
fgorospe76 is offline   Reply With Quote
Old 05-10-2011, 01:20 PM   #5
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
nakita ko nga yang sayo ng nag punta kami jan ni armando hehheheh
rosco is offline   Reply With Quote
Old 05-11-2011, 01:38 AM   #6
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
I like the idea of this guy did. wrapping it with aluminum.
Link
ricepower is offline   Reply With Quote
Old 05-11-2011, 03:04 AM   #7
marble_bearing
marble_bearing's Avatar
Drives: 2008 yaris y silver
[QUOTE=ricepower;579559]I like the idea of this guy did. wrapping it with aluminum.
Link
[/QUOTE
para d2 pala yung binili mo kahapon? hmmm ok na ok sya... gawin din yung sa akin pwede?
marble_bearing is offline   Reply With Quote
Old 05-11-2011, 04:39 AM   #8
ricepower
ricepower's Avatar
[quote=marble_bearing;579568]
Link
[/QUOTE
Sure! Dalhin ko sa Friday..kaya sama ka na!
Old 05-11-2011, 02:12 AM   #9
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@ricepower, any idea what kind of wrapping aluminum should be use?
rye7jen is offline   Reply With Quote
Old 05-11-2011, 02:28 AM   #10
ricepower
ricepower's Avatar
The aluminum wrapping used is available at any a/c supply shop and they often called Aluminum Flexible Duct Pipe . You may have to choose the smallest diameter as the one i saw yesterday is 4" and it cost SR 35 for a meter.
Old 05-11-2011, 02:56 AM   #11
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
^Thanks!
Old 05-18-2011, 11:16 AM   #12
syntax
syntax's Avatar
mga kayaris central ,,, kelan natin i sked ang A/C insulation na ito?
Old 05-19-2011, 08:12 AM   #13
rosco
rosco's Avatar
sa pagbalik ko na lang
kahit walang aluminum tape..
Old 12-05-2011, 01:24 PM   #14
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
@ Pao line me up man, I want this
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 12-05-2011, 03:08 PM   #15
syntax
syntax's Avatar
you got it man ! pagbalik mo wehehheehe
Old 12-05-2011, 03:10 PM   #16
charlieXX
Corporate Slave
charlieXX's Avatar
You da man!!! ano pa isunod natin pre sarap tumambay sa talyer eh puro tawanan
Old 01-17-2012, 12:04 PM   #17
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol charlie, tirahin na natin ito...
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 01-17-2012, 02:37 PM   #18
charlieXX
Corporate Slave
charlieXX's Avatar
duke oo pila na ako diyan para handa sa tag init
DIY: A/C Insulation texkid DIY / Maintenance / Service 219 08-02-2016 03:33 AM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
