I had the same "problem" with the throttle Controller system I installed. It gave me the FITS ! I then dabbed some CRAMOLIN on the contact pins of the connectors, and NO MORE PROBLEMS EVER CAME ABOUT. The Cramolin ensures a positive no-resistance connection on the pins and that ensures the ECU will not throw the system into "limp mode" I'll be you have the same type of problem. You can find cramolin (or DeoxIT) at electronics parts stores. if you can't, remove the throttle connector at the pedal, and clean the pins, and then re-insert the connectors again. Garanz, Bro.... you'll fixum doin that!
