Old 01-12-2007, 03:45 AM   #1
03Z33
03Z33's Avatar
Drives: TCR10
If you replace you shocks/struts with stiffer ones without increasing the spring rates, you may see a slight improvement in roll stiffness but the trade-off will be a much harsher ride and less control at the limit. You may look into some height adjustable coilovers which will allow you to run the car at stock height and you can also benefit from a stiffer front sway bar and adding a rear sway bar.
03Z33 is offline   Reply With Quote
Old 01-12-2007, 09:14 AM   #2
St_G
Drives: Black 2007 Yaris Liftback 1.5
I can see how the higher ride height could mean less control at the limit (which is fine, since I don't drive the Yaris at the limit), but can you explain why stiffer shocks and stock springs would lead to a harsher ride than stiffer shocks and lower springs?
St_G is offline   Reply With Quote
Old 01-12-2007, 09:51 AM   #3
03Z33
03Z33's Avatar
Drives: TCR10
The ride height won't affect the control, it's the mismatched spring/shock combination. Just like having a worn out shock that's too soft will cause bouncing and dangerous driving, a shock that's too stiff can cause undesired affects also. The spring won't be able to go through the proper travel because the shock will over dampen the motion. Little bumps in the road will feel much bigger and more pronounced.
Old 01-12-2007, 10:14 AM   #4
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Any idea why I can't get some shorter (energy suspension) sway bar end links, since going a little over 2" lower in the front, I would have thought Tanabe would have recomended this with their DF's.
Ive changed them on trucks that i've had where we went lower then 2".
Old 01-12-2007, 10:20 AM   #5
03Z33
03Z33's Avatar
Drives: TCR10
My Silk Road coilovers came with new adjustable sway bar links. Even at the longest setting they are much shorter than stock. I'll take some pics of them for you when I get a chance (they're already on the car). They should be real easy to duplicate, or you can try to buy them separate from any SK dealer (I got mine from John at Bulletproof).
Here's a pic of the end link:
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
lowering price - just installing tanabe springs ASHRAF Australia 94 01-27-2007 08:30 AM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 12:42 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
