Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Dezod, a couple of quick ones for you if you can spare the time please.
Can you have full control over the variable cam timing? Can you convert it to run on speed density or map sensed? Assuming I run some nice large duration cams with bugger all vacuum at idle, is it capable of accommodating that? By the way, these questions are all related to using it on an Echo, whether that makes things easier or harder, I don't know. |
#2 | |
The Scion Guru
Drives: Scions Join Date: Feb 2007
WHY WOULD YOU WANT TO RUN SPEED DENSITY!?!?! You are out of your mind if you want to do this! Use the MAF as the APR was designed to do. The MAF is MUCH more accurate and provides baro change correct, temp and humidity correction all in one. With MAP (Speed density) you must do that on your own. Stick with the MAF, use it's accuracy and be done with it. (also, don't worry about maxing it out, if you do you can run a GM 650g/s^2 MAF with the APR or even twin MAFs!) Take the 3D modeling of air and enjoy. As far as cams, we've done 264s on the 2AZ tC without issues at all. We are now about to do some 280/272s to see what's up. I would not be concerned with cams and this unit at all. We've even run 850cc injectors too. No problems there either.
Dezod Motorsports Inc-'We ARE performance." P: 716-681-6666 E: sales@dezod.com W: www.dezod.com Your leading source for all of your performance needs! From turbos and components, to brakes and suspension, Dezod has you covered. |
#3 | ||||
.Quote:
Thanks for the replies Dezod. Cheers, Rob. |
| Thinking of Swapping your Gauge Cluster? | Sabretooth | Cosmetic Modifications (Exterior/Interior) | 3 | 08-17-2009 05:18 PM |
| Swapping Out Gauge Pack | schreck | Fuel Economy Forum | 80 | 07-16-2009 12:53 PM |
| Help with ideas of swapping system out of my other car to my yaris | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 01-22-2009 01:23 AM |
| Swapping Rear Seats - 3 door | youcbs | General Yaris / Vitz Discussion | 1 | 06-21-2007 09:07 PM |
| Swapping seats question | Presto | General Yaris / Vitz Discussion | 6 | 05-01-2007 03:25 PM |
