Old 06-07-2010, 05:52 PM   #1
Dezod
The Scion Guru
Dezod's Avatar
Drives: Scions
Originally Posted by rob323 View Post
Dezod, a couple of quick ones for you if you can spare the time please.
Can you have full control over the variable cam timing?
Can you convert it to run on speed density or map sensed?
Assuming I run some nice large duration cams with bugger all vacuum at idle, is it capable of accommodating that?
By the way, these questions are all related to using it on an Echo, whether that makes things easier or harder, I don't know.
No control over VVT. To be honest, we offered it in the AEM EMS we did for the Scion tC. Most people did not take the cumbersome efforts of tuning it, so it was left by the way side. The ARP lets the stock control it, which works just fine as it does a good job (not the best) in controlling it.
WHY WOULD YOU WANT TO RUN SPEED DENSITY!?!?! You are out of your mind if you want to do this! Use the MAF as the APR was designed to do. The MAF is MUCH more accurate and provides baro change correct, temp and humidity correction all in one. With MAP (Speed density) you must do that on your own. Stick with the MAF, use it's accuracy and be done with it. (also, don't worry about maxing it out, if you do you can run a GM 650g/s^2 MAF with the APR or even twin MAFs!) Take the 3D modeling of air and enjoy.
As far as cams, we've done 264s on the 2AZ tC without issues at all. We are now about to do some 280/272s to see what's up. I would not be concerned with cams and this unit at all. We've even run 850cc injectors too. No problems there either.
Dezod Motorsports Inc-'We ARE performance."
P: 716-681-6666
E: sales@dezod.com
W: www.dezod.com
Your leading source for all of your performance needs! From turbos and components, to brakes and suspension, Dezod has you covered.
Dezod is offline   Reply With Quote
Old 06-07-2010, 06:04 PM   #2
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Understandable, but I guess most people wouldn't have access to a free engine dyno .
WHY WOULD YOU WANT TO RUN SPEED DENSITY!?!?! .......Use the MAF as the APR was designed to do. The MAF is MUCH more accurate and provides baro change correct, temp and humidity correction all in one. With MAP (Speed density) you must do that on your own. Stick with the MAF, use it's accuracy and be done with it. (also, don't worry about maxing it out, if you do you can run a GM 650g/s^2 MAF with the APR or even twin MAFs!) Take the 3D modeling of air and enjoy.
A hang over from my Mitsubishi days I guess (ECMlink), but the reason for my question was because down the track I see itb's in my future. To run the maf, I'll need to build a plenum for them (which is probably what will happen anyway). It's good to know that I'm not stuck with the stock maf at least.
I'm not going to debate that, afterall I did build an Echo rally car.
Please let me know how the 280's go. Does the lack of airflow across the maf at idle cause any problems or can that be compensated for?
Thanks for the replies Dezod.
Cheers,
Rob.
rob323 is offline   Reply With Quote
Thinking of Swapping your Gauge Cluster? Sabretooth Cosmetic Modifications (Exterior/Interior) 3 08-17-2009 05:18 PM
Swapping Out Gauge Pack schreck Fuel Economy Forum 80 07-16-2009 12:53 PM
Help with ideas of swapping system out of my other car to my yaris YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 5 01-22-2009 01:23 AM
Swapping Rear Seats - 3 door youcbs General Yaris / Vitz Discussion 1 06-21-2007 09:07 PM
Swapping seats question Presto General Yaris / Vitz Discussion 6 05-01-2007 03:25 PM
