#1 | |
Toyo Lover
![]() I have not the D2 at the time, i've ordered the brake in USA (I'm from Germany) and i'm still waiting of it, i hope i get it in 4-5 weeks. I can write a report when I have the D2
#2 | |
AKA Samurai Racer
i spoke to toyota and they say the TS comes with different discs from the normal yaris , my fronts are "warpped" or have a shudder on them when i hit the brakes on hi-speed , so they have a new set arrving in 1 week for me |
#3 | |
black shark
Drives: black toyota yaris t3 sprit Join Date: May 2010
the warpped happens when the disc are hot and water get on to them, or your pads are damaged, they break some times when water gets them, also if u have a hard brake pad does the same,
www.justbabynappies.co.za |
#4 | |
AKA Samurai Racer
well , toyota is replacing it under warrenty so no need to buy others now , but later i want to look into maybe a Rota big brake kit , but i need to check the TS disc specs as its not the same as the normal yaris , its a little bigger. yeah , not sure what caused it , but will see when the new discs and pads arrive in 1 week time from japan. |
#5 | |
Toyo Lover
Unfortunately, this is normal by Yaris TS Only a new brake system helps
AKA Samurai Racer
you mean the brake shudder is normal ? cant be ? i spoke to another TS owner the other day here is South Africa , he doesnt have any brake shudder , i never use to have it , since i got the car on 1000km till now on 8000km the shudder has developed.
#7 | |
Toyo Lover
Yes, i mean the brake shudder. I know 6 TS drivers they have the same problems. In my car it was from the beginning to... that's why i ordered the D2 Brake. |
#8 | |
AKA Samurai Racer
i wonder if the celica aftermarket discs will work , as the TS has 275mm discs , and so does the stock celica with the 2zzge motor in ? |
AKA Samurai Racer
do you know of any other problems that the TS has ? or what to look out for ?
#10 | |
Toyo Lover
Do you want a complete new braking system or only other discs?No, there aren't big problems. You should look only now and again after the oil. Because after a fast ride, the TS needs oil. Last edited by RedVitz; 06-11-2010 at 02:32 AM. |
| OEM Yaris brake pad kit PICS | auxmike | DIY / Maintenance / Service | 17 | 11-24-2009 11:42 AM |
