Old 06-09-2010, 03:07 AM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Originally Posted by RedVitz View Post
Yes, i know the mixed opinions about D2, but i know someone, he has a D2 8 Piston on his Subaru Impreza WRX STi and he's completely satisfied with the brake. There's no fading or flapping. And he does not spare the brakes
I have not the D2 at the time, i've ordered the brake in USA (I'm from Germany) and i'm still waiting of it, i hope i get it in 4-5 weeks.
I can write a report when I have the D2
thanks for the report back buddy , i will look into it.
i spoke to toyota and they say the TS comes with different discs from the normal yaris , my fronts are "warpped" or have a shudder on them when i hit the brakes on hi-speed , so they have a new set arrving in 1 week for me
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 06-09-2010, 04:36 AM   #2
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
hi buddy why dont u try A.T.E disc, they dont work bad at all had them on my bmw box, and they can withstand kak driving, ferodo ds pads are well, or u can get brake pads from stop tech, u can call Sav speed or windgate im not sure if windgate is right will ask my dad when i see him, they brake specialist, u can also look at the back of the car mag, or speed and sound,
the warpped happens when the disc are hot and water get on to them, or your pads are damaged, they break some times when water gets them, also if u have a hard brake pad does the same,
www.justbabynappies.co.za
nazier is offline   Reply With Quote
Old 06-09-2010, 05:09 AM   #3
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
hey buddy
well , toyota is replacing it under warrenty so no need to buy others now , but later i want to look into maybe a Rota big brake kit , but i need to check the TS disc specs as its not the same as the normal yaris , its a little bigger.
yeah , not sure what caused it , but will see when the new discs and pads arrive in 1 week time from japan.
JDMtuner
www.jdmtuner.co.za
Old 06-09-2010, 09:56 AM   #4
RedVitz
Toyo Lover
RedVitz's Avatar
Drives: Yaris TS XP9 VFL
Send a message via ICQ to RedVitz
That's normal, a new set brings nothing Unfortunately, this is normal by Yaris TS Only a new brake system helps
RedVitz is offline   Reply With Quote
Old 06-10-2010, 01:17 AM   #5
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
you mean the brake shudder is normal ? cant be ? i spoke to another TS owner the other day here is South Africa , he doesnt have any brake shudder , i never use to have it , since i got the car on 1000km till now on 8000km the shudder has developed.
JDMtuner
www.jdmtuner.co.za
Old 06-10-2010, 01:37 AM   #6
RedVitz
Toyo Lover
RedVitz's Avatar
Yes, i mean the brake shudder. I know 6 TS drivers they have the same problems. In my car it was from the beginning to... that's why i ordered the D2 Brake.
Old 06-10-2010, 08:33 AM   #7
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
ahh ok i see , so it seems to be a widely noted problem then , thanks for the information buddy .
i wonder if the celica aftermarket discs will work , as the TS has 275mm discs , and so does the stock celica with the 2zzge motor in ?
JDMtuner
www.jdmtuner.co.za
Old 06-10-2010, 08:34 AM   #8
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
do you know of any other problems that the TS has ? or what to look out for ?
JDMtuner
www.jdmtuner.co.za
Old 06-10-2010, 12:29 PM   #9
RedVitz
Toyo Lover
RedVitz's Avatar
I don't know whether this fits, sry. But I can find this out. Do you want a complete new braking system or only other discs?
No, there aren't big problems. You should look only now and again after the oil. Because after a fast ride, the TS needs oil.
Old 06-11-2010, 01:14 AM   #10
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
No, there aren't no big problems. You should look only now and again after the oil. Because after a fast ride, the TS needs oil.
yes , at the moment im looking to change just the discs for now to better ones.
ah ok thats good news , i keep a eye on the oil level , mine has never dropped since i have had it , never needed to fillup , but , will keep a eye on that , thanks buddy.
JDMtuner
www.jdmtuner.co.za
OEM Yaris brake pad kit PICS auxmike DIY / Maintenance / Service 17 11-24-2009 11:42 AM
