Old 06-09-2010, 09:56 AM   #1
RedVitz
Toyo Lover
RedVitz's Avatar
Drives: Yaris TS XP9 VFL
Send a message via ICQ to RedVitz
Originally Posted by aucorium View Post
thanks for the report back buddy , i will look into it.
i spoke to toyota and they say the TS comes with different discs from the normal yaris , my fronts are "warpped" or have a shudder on them when i hit the brakes on hi-speed , so they have a new set arrving in 1 week for me
That's normal, a new set brings nothing Unfortunately, this is normal by Yaris TS Only a new brake system helps
RedVitz is offline   Reply With Quote
Old 06-10-2010, 01:17 AM   #2
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
you mean the brake shudder is normal ? cant be ? i spoke to another TS owner the other day here is South Africa , he doesnt have any brake shudder , i never use to have it , since i got the car on 1000km till now on 8000km the shudder has developed.
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 06-10-2010, 01:37 AM   #3
RedVitz
Toyo Lover
RedVitz's Avatar
Yes, i mean the brake shudder. I know 6 TS drivers they have the same problems. In my car it was from the beginning to... that's why i ordered the D2 Brake.
Old 06-10-2010, 08:33 AM   #4
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
ahh ok i see , so it seems to be a widely noted problem then , thanks for the information buddy .
i wonder if the celica aftermarket discs will work , as the TS has 275mm discs , and so does the stock celica with the 2zzge motor in ?
JDMtuner
www.jdmtuner.co.za
Old 06-10-2010, 08:34 AM   #5
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
do you know of any other problems that the TS has ? or what to look out for ?
JDMtuner
www.jdmtuner.co.za
Old 06-10-2010, 12:29 PM   #6
RedVitz
Toyo Lover
RedVitz's Avatar
I don't know whether this fits, sry. But I can find this out. Do you want a complete new braking system or only other discs?
No, there aren't big problems. You should look only now and again after the oil. Because after a fast ride, the TS needs oil.
Old 06-11-2010, 01:14 AM   #7
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
No, there aren't no big problems. You should look only now and again after the oil. Because after a fast ride, the TS needs oil.
yes , at the moment im looking to change just the discs for now to better ones.
ah ok thats good news , i keep a eye on the oil level , mine has never dropped since i have had it , never needed to fillup , but , will keep a eye on that , thanks buddy.
JDMtuner
www.jdmtuner.co.za
Old 06-11-2010, 02:31 AM   #8
RedVitz
Toyo Lover
RedVitz's Avatar
Yes, the TS needs only oil after a fast ride on the highway. We haven't in Germany no speed limit, that's why you go faster and faster till the limiter and then the oil temperature is going to 130-137°C
But back to topic, i try to find out wether the celica discs work
No Limitation As A Limitation!
www.ajr-performance.com -> Custom High Performance Parts
OEM Yaris brake pad kit PICS auxmike DIY / Maintenance / Service 17 11-24-2009 11:42 AM
