![]() Drives: BT A4, VR6 Jetta, Yaris Join Date: Jun 2010
we have.. we even thought it was overtight, as her uncle pried to tightened it.
still does it. |
Half a Bubble Off Plumb
May have gotten a little contamination with oil, antifreeze or something. It's slipping at any rate. Clean the belt and pulleys really well with detergent and check the tightness. There are belt dressings, rosin and such that you could try if that doesn't work, I suppose.
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
Along the lines of belt dressings and such, and being a cheap ass shadetree sort of guy, I'll pass on that I've been told molasses or syrup works to increase a belt's coefficient of friction.
#5 | |
We got back home to PA, I loosened it some, its starting to squeal more. I know its from being looser, but if its slipping, its not affecting anything more then making noise. its not "loose" by any means. Its still very tight. I am thinking its the belt. I sprayed PB on it, thinking if the pulleys are nasty, it'd at least keep it quiet till i could clean them. I am going to pick up a better brand belt in a few minutes and replace it, cleaning the pulleys once the other belt is off. |
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 08:04 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Water Pump leaks and then stops | CB900F2 | DIY / Maintenance / Service | 30 | 05-09-2011 09:14 AM |
| Hmm my water pump failed again!!!! Could it be the pulley?!?! | YarisSedan | Performance Modifications | 64 | 10-05-2009 09:32 PM |
