![]() Drives: 2006 Yaris T1 Join Date: Jun 2010
ok, new plan! i want to do a Hertz?Audison install. After browsing the forums, it seems like that is a good way to go. I'm just worried about power consumption for the amps. will the 1 litre engine handle it?
#2 | |
Canadetroiter
If you are still worried about your charging system, you could always use a capacitor. Capacitors are great at taking the strain off of your car's charging system. Unlike a battery, they provide instant power to your amp for musical peaks like bass notes, because they charge and discharge very quickly. The general guideline for capacitors is 1 farad per 1000 Watts. So if you have an amp with 500 Watts or less, a 0.5 farad capacitor should be fine. You could even use a 1 farad cap if you can't find a 0.5. You can't have too much capacitance.
ok super! so with a bit of work, i should be able to get a 10" sub, a decent split up front and some good coax's to fill the rear? provided of course that i stay around 1000 watts.... tahnks for the help! with time i should be able to get the bits and pieces and do the install!
| Rear speaker of the Yaris HB. | zinou2009 | Africa | 2 | 07-09-2012 03:27 AM |
| whats the stock offset on yaris rs? | marcus | General Yaris / Vitz Discussion | 2 | 04-16-2007 11:53 AM |
