Old 06-09-2010, 02:36 PM   #1
127.0.0.1
Originally Posted by euroa4 View Post
we have.. we even thought it was overtight, as her uncle pried to tightened it.
still does it.
if you burnt the belt from it being too loose initially, then the squeal
may never stop
Old 06-09-2010, 02:38 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Along the lines of belt dressings and such, and being a cheap ass shadetree sort of guy, I'll pass on that I've been told molasses or syrup works to increase a belt's coefficient of friction.
Old 06-09-2010, 02:49 PM   #3
euroa4
Drives: BT A4, VR6 Jetta, Yaris
may never stop
When it was first put on, it was VERY tight. The alt was pried over, you could barely twist the belt. It squealed some then.
We got back home to PA, I loosened it some, its starting to squeal more. I know its from being looser, but if its slipping, its not affecting anything more then making noise. its not "loose" by any means. Its still very tight.
I am thinking its the belt.
I sprayed PB on it, thinking if the pulleys are nasty, it'd at least keep it quiet till i could clean them.
I am going to pick up a better brand belt in a few minutes and replace it, cleaning the pulleys once the other belt is off.
euroa4 is offline   Reply With Quote
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
