AKA Samurai Racer
do you know of any other problems that the TS has ? or what to look out for ?
#2 | |
Toyo Lover
Do you want a complete new braking system or only other discs?No, there aren't big problems. You should look only now and again after the oil. Because after a fast ride, the TS needs oil. Last edited by RedVitz; 06-11-2010 at 02:32 AM. |
#3 | |
AKA Samurai Racer
yes , at the moment im looking to change just the discs for now to better ones. ah ok thats good news , i keep a eye on the oil level , mine has never dropped since i have had it , never needed to fillup , but , will keep a eye on that , thanks buddy. |
#4 | |
Toyo Lover
and then the oil temperature is going to 130-137°CBut back to topic, i try to find out wether the celica discs work
No Limitation As A Limitation! www.ajr-performance.com -> Custom High Performance Parts |
#5 | |
AKA Samurai Racer
haha , i like the no speed limit rule , i have only been to 200 kph twice in my car , as here there is alot of speed traps. but i will check the oil again to see my level. ok great , thank you , let me know what you find out , would be cool if the celica aftermarket discs could work on the TS. |
#6 | |
black shark
Drives: black toyota yaris t3 sprit Join Date: May 2010
if the oil is going to give problems then change it with a high performance oil, also u need to keep a eye on brake fuild, if the disc are getting warpped that means the temp is high, brake fuild boils at 200 and something degrees, find out what dot is in your car and change to a higher one, that should help also
www.justbabynappies.co.za |
| OEM Yaris brake pad kit PICS | auxmike | DIY / Maintenance / Service | 17 | 11-24-2009 11:42 AM |
