Usually clinking sound while turning that is always present on one side or the other is typically a failing CV joint. Although when you had your tires rotated they should have seen the grease splatter on the inside of the wheel and the area of the joint and informed you. If you look up under the car you can confirm this on the right side. If you see grease everywhere you know its a axle. Typical cost of repair can be expected between 180-250 parts and labor.
#2 | ||
![]() ![]() Drives: 06 Yaris YR Hatch Join Date: Nov 2008
Thanks for all of your help so far guys!
![]() Quote:
![]() Australian Toyota's come with a standard 3 year warranty, though the dealers generally offer extended warranty if you get your car serviced at that dealer for the first three years. So mine would just be onto the extended warranty now. 'If' there's something wrong with it (and it isn't just a loose wheel lug or something), I'm going to refuse to pay for the repairs and demand it be made a warranty issue - This is from the mob, after all, who can't even replace my wiper blade without stuffing it up! |
| Clicking noise when jerking steering wheel side to side/hit bumps left side | eii | DIY / Maintenance / Service | 8 | 03-22-2010 06:46 PM |
| Humming noise when turning the steering wheel!! Help?? | mhkritzinger | DIY / Maintenance / Service | 7 | 09-28-2009 08:27 AM |
| Noise when turning | acuraphile | DIY / Maintenance / Service | 3 | 07-22-2009 02:25 PM |
| Radio noise.. need help | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 12-06-2008 04:21 PM |
| Clicking noise in center console? | devinlamothe | General Yaris / Vitz Discussion | 8 | 09-16-2006 11:03 AM |
