Old 06-16-2010, 07:48 AM   #1
I like those white Mini Cooper wheels (I actually like almost all of the wheels that I see on Coopers).
I run a set of the 5 spoke Mini rims as my Winter rims. Their lug bolts are larger diameter than our studs and the hub is 2mm wider. If you aren't running hubcentric rings (I couldn't find ones to fit), you should use lug nuts that make the wheels lugcentric. I am using lugcentric bulge conical lug nuts that I found at Jegs that have the correct taper and have a part below the taper that fills the space between our studs and the wheel:
http://www.jegs.com/i/Detroit+Wheels...395-5/10002/-1
Old 06-16-2010, 08:05 AM   #2
bobselectric
Kickin' Yaris
bobselectric's Avatar
Drives: 07 Yaris liftback
Is there anything you don't know?
Tags
cooper, mini, red, wheels, white
Mini Cooper S vs. Yaris six6two New YARIS Purchase Forum 64 02-03-2015 10:28 AM
FS: Mini Cooper to Yaris hub centering rings... DerFlosser Items for Sale by private party 2 03-27-2010 07:53 PM
Mini Cooper Countryman wooverstone8 Off-topic / Other Cars / Everything else Discussions 3 01-22-2010 10:25 PM
Thinking of trading Yaris for Mini Cooper S convertible. marcus General Yaris / Vitz Discussion 94 06-26-2009 08:38 AM
