![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
its sticking a little bit... I assumed it was a spring that pulls the gear back off the mechanism
after you let go of the key...Is it a clutch type thing nowadays??? I asked a starter guy and he said replace the spring and 2 contacts ... he said he had seen some of these... |
#2 | |
#3 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
When the contacts wear a lot, the contacts arc and fuse together with the plunger copper ring briefly and causes it to stick. this would be the typical 'hit it with a hammer to unstick it' scenario |
#4 | |
replace the plunger and contacts call these guys, tell them your starter model, and they should be able to source you a plunger and set of contacts http://www.nationsautoelectric.com/densoparts.html |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
This kind of solenoid switch is generally not repairable - you replace the whole thing. The cap is crimped to the barrel - not designed to be serviced.
Examine the gear teeth on the flywheel - if they are chewed up, it can cause sticking as well. |
| Remote Starter - Tail Light Problem | Chrsto4 | General Yaris / Vitz Discussion | 4 | 10-31-2009 11:36 PM |
| Remote Starter | Mistry | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 09-14-2009 01:32 AM |
| Starter problem | wormley | DIY / Maintenance / Service | 2 | 10-29-2008 09:56 AM |
| starter kill & horn help | spechuy | DIY / Maintenance / Service | 0 | 10-20-2008 01:30 PM |
| Starter dragging | YarisTom73 | DIY / Maintenance / Service | 5 | 08-27-2007 12:11 PM |
