Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
So does the vvti just retard the cam, or advance it?
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
The VVTi retard and advance the camshaft angle based on the engine:
- RPM - Temperature - Load If you see the image below you can notice that the camshaft is being advanced or retarding according these factors. Although there are six diagrams of camshaft angles, three of them are matched with others. I marked them for you to understand with ease. It is hard to notice correctly if the overlaps are the same but if you see accurately, the camshaft angle figures are labeled with a 7-digit number. Some of them are actually the same label so it makes me think that infact they are at the same position. So lets make a summary of this: Camshaft Angle 1 - Fully Retarded During idling \ Light Load (1a) = At Low Temperature (1b) = Upon Starting \ Stopping Engine (1c) Camshaft Angle 2 - Fully Advanced At medium Load (2a) = In low to Medium Speed Range with Heavy Load (2b) Camshaft Angle 3 - Retarded but more advanced than Angle 1 In High Speed Range with Heavy Load Still.... if you notice the 2nd and 3rd diagrams you will notice that the valve has only two ports and not three, which I am thinking are Angles 1 and 2. So that makes me think, where would the valve be at Angle 3? |
Half a Bubble Off Plumb
Got a link to that 1NZFE Spec Details.pdf document?
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
