Old 06-18-2010, 10:37 AM   #1
bronsin
bronsin's Avatar
Sure I did/do it all the time with my ECHO and now with my Suzuki DL1000. Its a good skill to have. Once on a 500 mile trip from home my Toyota pickup had the clutch pedal freeze in the up position. You couldnt push it dowm. A bolt had worked out and got jamed in the mechanism. I had to R&R the trans and fix it. But before I could do that I drove 500 miles home with no clutch! If youre wondering how to start moving heres how: put the trans in first and crank the engine. The vehicle will move and the engine start. If you have a "push the clutch in to start" car, then youll have to disable it. First thing Idid on my ECHO.
Clutchless shifting on my Suzuki is incredibly smooth. Even downshifting. That transmission is amazing.
Old 06-18-2010, 12:21 PM   #2
Kongo-Otto
Drives: '09 Yaris & '10 Auris
It is because it has a straight gearbox, like most other regular motorcycles. You can shift up without a clutch and if you are not doing it completely wrong there will be no more wear to the transmission.
Downshifting without clutch needs a little more practice and i would not recommend it even if it could work smoothly.
Old 06-18-2010, 01:00 PM   #3
bronsin
bronsin's Avatar
Practice on a Zuk DL1000 and you'll be an expert in no time!
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 01:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
c one motorsport clutch line(pics) badhabitz Performance Modifications 6 07-31-2006 10:08 AM
