Old 06-19-2010, 05:44 AM   #1
djct_watt
Drives: 2010 NCP91 5spd
^if you are doing it right there should be no pop sound. You need to shift to neutral at zero load; it's the moment you're neither applying
power nor engine braking.
Old 06-19-2010, 07:27 AM   #2
bankrobber
Drives: 2007 Yaris Hatchback
You need to pull it out of gear at the same time you let off the gas. If not exact on timming you will force it out of gear.
bankrobber is offline   Reply With Quote
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 01:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
c one motorsport clutch line(pics) badhabitz Performance Modifications 6 07-31-2006 10:08 AM
