Old 06-19-2010, 01:59 PM   #1
ddongbap
Originally Posted by djct_watt View Post
Uuuuh. . . they both use C50 transmissions. . .
O. Maybe. The gearing is different. Thats all I was getting to.
Old 06-19-2010, 06:28 PM   #2
djct_watt
Drives: 2010 NCP91 5spd
According to these sites,
http://www.vibratesoftware.com/html_...ear_Ratios.htm
http://www.vehix.com/car-reviews/200...specifications
http://www.yarisworld.com/forums/showthread.php?t=4997
They are exactly the same. Maybe the sites are wrong? The only difference is the final drive (which is easily changed between transmissions). But the gear ratios are the same.
djct_watt is offline   Reply With Quote
Old 06-19-2010, 08:02 PM   #3
Billiam
Drives: '10 White Yaris 4D LB
BTW...rev-matching is just bringing the engine rpm up to match the tranny's output shaft speed...usually when down shifting. It's got nothing to do with "double clutching".
Old 06-21-2010, 09:36 PM   #4
ddongbap
No. You are totally right. That final drive was different. I just forgot or didn't care. Hahaha
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 01:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
c one motorsport clutch line(pics) badhabitz Performance Modifications 6 07-31-2006 10:08 AM
