Old 06-19-2010, 09:45 PM   #1
Check the 10A HAZ fuse. It feeds the flash relay.
The HAZ fuse is in the fuse panel under the hood by the way.
Old 06-19-2010, 10:40 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
I have a spare yaris flasher you can have $40.00, but it would take 6-8 days to get to you .
As i have a lexus LED flasher in mine now
Old 06-19-2010, 11:09 PM   #3
jon@swoveland.com
Drives: 2007 Yaris HB
Thanks so much for the offer 1NYaris1, unfortunately that would be cutting things pretty close...going away early for the long weekend, and I still need to get the wiring harness done, which won't happen until the signals work again...
jon@swoveland.com is offline   Reply With Quote
Old 06-19-2010, 11:18 PM   #4
Did you check the fuse yet?
If the relay assembly is truly fried, I have an extra as well, that I can ship from Connecticut, which might get there a bit faster.
Old 06-19-2010, 11:26 PM   #5
jon@swoveland.com
CTScott - I thought for sure I had checked that fuse with my fuse tester, anyhow, this time I pulled it, and sure-enough it was blown. I put in a spare and .... flashers still didn't work! Then I realized I hadn't put the relay module back in. Plug'd her back in and voila...signals!
CTScott, I definitely owe you a cold one!
Thank-you everyone who posted, what a fabulous forum!
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 11:12 AM
Indicator relay removal Yariscoyne DIY / Maintenance / Service 9 01-07-2011 03:42 PM
Horn Relay? MGargano DIY / Maintenance / Service 7 11-14-2009 06:01 PM
Request for help: diagramming a relay BailOut In Car Entertainment + Electronics (audio / video / alarm) 25 07-12-2009 12:59 PM
Relay Question Liu997 DIY / Maintenance / Service 8 04-25-2009 10:58 AM
