Old 06-20-2010, 05:19 PM   #1
kou
Drives: 08 lb
THROTTLE BODY SWAP NO CEL!!!!
So i did the swap without getting a cel ever. THANK YOU jkuchta for the info.I ordered a new intake manifold, a yaris and a corrola throttle body.Step one was to fill in all the cavaties on the manifold with JB weld then port the opening as much as i could. swapped the chips over on the throttle bodies and removed the epoxy from the idle adjustment screw,then switched everthing over, did a pre adjustment on the idle screw and made a paper gasket which is siliconed in place.
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
1ZZ-FE throttle body crxgames Items for Sale by private party 1 04-27-2009 05:19 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 07:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
