Thanks for the write up. Got it done after hassleing with the torx bolts. My question now is for those who have removed the seats. Any tips for storing the bench in good condition? What did you guys do? Thanks.
![]() ![]() Drives: 2010 Yaris 3-door liftback MT Join Date: Nov 2009
How much additional vertical clearance in the storage area?
I'm considering removing my 60/40 rear seats in my '10 LB to create more space for hauling. First item on my list: a 30" range. Best way to fit it in completely would be to have the 30" dimension of the range (which is the width of the range when it is oriented normally in a kitchen) oriented vertically in the car. In other words, the range would be on its side.
How much additional vertical clearance do you get from removing the rear seats in a LB? |
#3 | ||
Only Happy When it Rains
Colin Chapman disciple |
![]() ![]() ![]() ![]() Join Date: Feb 2010
I never thought i would take out the back seat. However i had a bag of salt/calcium chloride mix break open and it all over the place under the seats, spare tire, under the side molding. Freakin mess! Gota take the seat out to get it all cleaned out.
That's ashame. Good luck. Try and find the cargo tray and get it. Worth what I paid back when.
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
Cargo Tray? Is this something pre-made for a yaris HB with the rear seat removed?
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
Actually it was made as a Toyota accessory to use with the seat in. When I removed my seat which the back of secures the tray in place (to keep it from sliding forward), I fabricated some brackets and plastic to use the seat bolt holes to keep it secured now. Works like a champ. Had to, as I use this vehicle on occasion to fill my fuel containers and didn't want any spills. Easy to clean also.
Sitting in my shop covered in plastic. Probably sell it.
| front seat room | Bigdaddy727705 | General Yaris / Vitz Discussion | 9 | 10-30-2013 12:26 PM |
