#19 |
1. 03Z33
2. heylookitsjames 3. kngrsll 4. acrbill 5. dngz 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. |
#20 |
dngz, thanks for joining! I added you to the original post too :)
#21 |
so this bolts right into place?
#22 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
yeah i have a question, you say it bolts to the stock spring cups? is that the top of the springs, inside the trunk/hatch or outside the car underneath??? I don't want anything taking up my trunk space.
#23 | |
This is honestly going to be one of the simplest installs on this car, it shouldn't take more than 20 min. and simple hand tools. You probably won't even have to remove the wheels. Here is a picture of the bar on the Scion Xb/Xa: ![]() Keep in mind that the Scion had a sway bar built into the stock trailing arm also, which we don't even have. This is going to make a big improvement on our cars! Punch, thanks for the PM! I added you to the list |
#24 |
![]() ![]() Drives: Yaris 3dr Hatch/Black Join Date: Feb 2006
woof is seriously, seriously interested. Right now, you're saying $140 delivered, right? Well, will it come with photographic instructions?
#25 |
Apexing Egg!!
sway bar install's are one of the easiest mod's to do really.
oh, ive got a friend with a yaris, he seems intrested. i sent him the link to the thread, but he isnt that great with the internet so i may be doing all that for him, so we will see. ill try and contact him again and see whats up.
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#26 |
i dont think it is that simple... u gotta remove the stock sway bar first!
#27 | |
![]() ![]() ![]() Drives: Polar White Hatch Join Date: Nov 2006
I sure hope that its a bit more involved than the sway bar for the Scion since that sure doesn't look like it is going to do anything. Its a bar that is attached to a solid rear beam axle and nothing else. Seems like it would be like trying to stiffen a pencil by gluing a tooth pick to it. You would think it would be mounted to the chassis at some point.
ChinoCharles Intake supporter. |
#28 |
Lurker supreme!
Drives: old and boosted! Join Date: Nov 2006
Is the progress rear sway bar going to be similar to the one in this article? sway bar for prius.
After reading that article, I understand how the bar would reduce understeer, which is good (to a point). But how would it work in connection with (or instead of) an front upper strut bar? Thanks!
2006 Red Blitzed RS 5-door |
#29 | |||||
This really will be as simple as just a few bolts, but it really does make a big difference.Quote:
The front strut bar, rear strut bar (upper), and other chassis reinforcement bars can help improve your handling also by reducing chassis twist. Most of the ones that go on the front, will theoretically increase chances of understeer and bars that go on the back should increase oversteer. In my oppinion, the rear sway bar is by far the most effective one from the above mentioned bars. largeorangefont is now confirmed, let me know if anyone else wants in! |
#30 |
#31 |
#32 |
HAHAHA my bad!! i just assumed the yaris would have one!
#33 |
ACRBILL add me to list for rear sway bar tks dansides
#34 |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Count me in!
1. 03Z33 2. heylookitsjames 3. kngrsll 4. acrbill 5. dngz 6.cdydjded 7. 8. 9. 10. 11. 12. 13. 14. 15. |
#35 |
Added dansides and cdydjded to the list, Thanks!
#36 |
did you see trd now has a rear sway bar for us?
| Response from Toyota on my special order | drdavidr4u | New YARIS Purchase Forum | 14 | 04-27-2010 08:59 PM |
| Sway Bar! | dngz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 55 | 01-12-2007 03:31 AM |
| C-One order 11/30/06 | BulletProofAuto | Sponsors Classifieds Area | 15 | 12-01-2006 04:43 PM |
