Old 06-21-2010, 05:46 PM   #1
yariseggvvti
Drives: Yaris Hatchieback
Looks good when you lower it. Since you lower it the installed the rear sway bar...might as well go for more handling upgrade. UR strut bar, UR front lower 4 point bar, UR rear strut bar, rear lower bar. I didn't even lower my car but it handles tight.
yariseggvvti is offline   Reply With Quote
Old 06-21-2010, 06:48 PM   #2
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
no offence at all but i want to point 1 thing.
i recently found out that on our cars, front strut tower bars (the one that goes in the engine bay) is completely for cosmetic purpose only.
Yaris has only 1 bolt sticking out from the front strut hat. Normally, other cars will have 2~3 bolts sticking out towards engine bay from the front suspension assembly. If the strut bar is bolted directly onto these bolts that originated from the suspension assembly, it will stablize and minimize the play between two front strut assemblies.
however, the yaris strut bar is not bolted onto the strut itself. it is simply bolted into holes around the top hat, and there is nothing beneath those holes.
in short, if you are solely making purchases for performance, you can skip the front strut tower bars.
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Suspension Bits soloecho2 Willing to Buy by private party 0 04-25-2010 08:59 AM
can someone measure stock ride height? thebarber Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 07-29-2009 03:02 PM
Stiffer suspension - same ride height? fuji Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-13-2009 08:53 PM
stock ride height or spring sag? mikeukrainetz General Yaris / Vitz Discussion 5 12-21-2006 02:00 PM
Air Ride suspension for Yaris Sedan fouad84 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 10-13-2006 08:39 AM
