Old 01-14-2007, 07:17 PM   #1
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Forget tinting - get heat reflective film instead, at least your car would be genuinely cooler in the Australian summer heat!
Changing the springs on this car is a fairly involving 2 hour process by one mechanic, most of it spent on the front end of the car. The strut tops are sitting under the windscreen wiper panels, therefore the wipers and its ancillaries have to come off before you can get to the strut tops.
Thereafter it is a straightforward process of dropping out the shocks, using a spring compressor to undo the springs and replacing them. The rears are dead easy and you essentially remove the retaining bolt on the rear shock absorber to swing the torsion beam bar far enough down to release the spring from its cradle.
After all that suspension work you should budget to send the car in for alignment, disassembling the front suspension bits tends to make the car's geometry go off a bit. Plus, the anticipated lower ride height also brings about a geometry change on its own.
I am not sure if TRD = TTE springs, but my TTE springs list for around AUD$450.
Spring compressor
Front spring comparison
Rear spring comparison
Old 01-15-2007, 05:19 AM   #2
jaspie
Lil White her name is ~
jaspie's Avatar
Drives: White YRX 5DR Hatchback 2006
Spring compressor
Where can I get heat reflective film ~ That's my main purpose.....get rid of that heat ~ Do i need to do it myself or?
Thanks for the explanation ~ 2 hours.....it'll probably take my 5 hours ~ Hehe ~
I'm hoping I can get a friend to do it for me ~ So I won't need to pay so much ~
I want my car to be low ^_^ ~
BTW.....yes that is AU$460 ~ King's springs + Installation ~ Also.....I can't seem to find any Lowering springs on eBay for the Yaris ~ Any help please ~
Jaspie ~
jaspie is offline   Reply With Quote
Old 01-15-2007, 07:22 AM   #3
cleong
cleong's Avatar
Where I am (Singapore) they are called solar film. V-kool is supposed to be the best, but is also the costliest. It costs around A$800 to do all the windows on the car. They reflect heat without screening out too much light, so you can still see out.
http://www.v-kool.com.au/automotive.html
I don't recommend you try to change springs on the car yourself. Get a workshop to do it. I don't want the car too low, there are killer humps and potholes scattered around the streets of Brisbane. ;)
Can't help you with regard to eBay springs but I recommend you get the springs fitted from the shop where you bought them. Good luck!
Old 01-15-2007, 09:56 AM   #4
jaspie
jaspie's Avatar
Well.....I checked online today for the window tinting ~ I found a package (includes window tint, paint protection and fabric protetion) for AU$390 and they use 3M film which I know is pretty good too ~ I'm going to go in tomorrow and ask about a few more stuff ~
Yea.....I don't plan on doing the springs myself ~ AU$460 for springs and installation and I heard King's springs use to really suck but after they fixed themselves up and re-organised the factory.....I heard King's springs are pretty reliable now ~
Will keep you guys updated ~
Jaspie ~
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Lowering Springs - Questions ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-10-2007 08:21 AM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 12:42 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
