#1 | |
Drives: yw calls me douche and racist. Join Date: Aug 2007
Sorry of my questions seem like I'm trying to prove you wrong. I'm just trying to figure it out. Btw, the gear accepts the shifter because its the right RPM range. Theres no grinding as it goes it. It just goes POP and takes it in. And only at the right RPM range, consistently. Now, you may be right, but I think its kinda hard to mis shift w/o the clutch, seeing as the gates won't open if you're at the wrong speed range. Anyways, long story short. Syncros are used to match difference in speeds on the clutch and the different gears. But if you go clutch-less, and use the engine to act as syncros, how would that put wear on the syncros? |
#2 | |
Half a Bubble Off Plumb
But if you think you can do it better without the clutch than with it, go ahead, wear it out. Don't come back here later complaining about Toyota's low quality transmission that tore up. |
#3 | |
I'm not mad at you.
#6 | |
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
-SAV
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
#7 | |
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 07:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Restarting car after popping the clutch... | PaidTimeOff | General Yaris / Vitz Discussion | 21 | 02-26-2009 01:40 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
| c one motorsport clutch line(pics) | badhabitz | Performance Modifications | 6 | 07-31-2006 10:08 AM |
