Old 06-23-2010, 10:56 AM   #1
toystory
Drives: 06 toyota yaris
The Yaris battery is good even, with the problem, the car still turns on. The Alternator has also been checked as I mentioned earlier.
I wanted to know if the Alternator is controlled by the ECU.....
toystory is offline   Reply With Quote
Old 06-23-2010, 12:13 PM   #2
No. It's not controlled by the ECU, but it puts out a pulsed signal to the ECM, the AC ECU, and the DRL to let them know if the alternator is generating power. That output signal is a function of the voltage regulator. The alternator could be generating power, but if that signal is being generated, then the ECM and the other systems that use that signal wouldn't think that it was. You'd need an oscilloscope to check for that signal.
Old 06-23-2010, 05:57 PM   #3
toystory
Thanks for the info. I'm gonna try to figure out what's going on, I don't have much experience but that's what threads are for. TY!
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
solar trickle charger and alternator wingdood Fuel Economy Forum 33 10-12-2009 04:02 PM
