Old 06-23-2010, 11:13 PM   #1
toystory
Drives: 06 toyota yaris
Originally Posted by Stove View Post
Add any new electrical/electronic items lately? If not, I'd still look at the alternator. I've had alternators test out as being good when they weren't. Auto parts store told me it was good and out of desperation I replaced it anyway and it fixed the problem. It wasn't on my Yaris but the symptoms were similar.
I only put a month and a half ago, 2 bulbs (lead) in the front for the signals and thats about it.
I wan't to know that if in a normal working car, a person disconnects the alternator, the car is gonna cut off PS, SPEEDOMETER, SIGANALS, RADIO, A/C, AIRBAG LIGHT WILL BE ON? JUST A CURIOSITY! TY....
toystory is offline   Reply With Quote
Old 06-23-2010, 11:27 PM   #2
I'll try it on Crashy tomorrow morning and let you know.
Old 06-24-2010, 12:13 PM   #3
OK - I just finished doing some testing on Crashy and could not recreate the issue. I disconnected the alternator output (the large gauge wire going to the battery) and separately the alternator "signal" output (the 4 pin connector that gives the ECM, AC ECU, etc. info about the alternator state). In both cases Crashy started and ran fine, and everything worked (power steering, etc.)
So, based on that and my experience with us having a plant in Humacao, PR for a few years (and seeing things corrode like crazy even indoors), I would look at connector A27, which is the large black connector with a black and a white wire. It connects to the fusible link (the large plastic chunk attached to the positive battery terminal). The white wire supplies power to all of the body ECUs (AC, Power Steering, SRS, etc.)
I would also check the other end of that white wire, which is a ring terminal (connector 1D), which is located on the bottom of the under hood fuse panel.
Old 06-24-2010, 12:29 PM   #4
toystory
Attachment 34677
I'm gonna check as soon it stops raining and i will let you now.... ty! It won't be long.......
Old 06-24-2010, 02:26 PM   #5
toystory
Thumbs up
Attachment 34677
YOU WERE RIGHT CTSCOTT!!!!!!
I TOOK OFF THE PLUG WITH THE BLACK AND WHITE WIRE WHERE YOU SHOWED IN THE PICTURE, AND SOMEBODY HAD DONE SOMETHING BEFORE, (CAR WAS BOUGHT USED), THEY PUT THE WIRES BENDED INTO THE PLUG TO MAKE CONTACT.... SO I TOOK EVERYTHING APART OF WHAT WAS DONE BEFORE, AND WITH A PLIER I TIED UP THE CONTACTS AND SQUEEZED IT DOWN AND LEFT EVERYTHING HOW ITS SUPPOSED TO GO, SO I TURNED THE YARIS ON AND EVERYTHING IS WORKING PERFECTLY WELL, THANKS SO MUCH! I'M GONNA DRIVE IT AND IF ANYTHING ELSE POPS UP I'LL WRITE IT HERE, HOPEFULLY NOT!!!!!!
Old 06-24-2010, 02:40 PM   #6
big lo
big lo's Avatar
Drives: 2007 VIOS
I think this guy is a toyota employee, he knows to much. KUDOS CT, and thanks again. Holla at me.
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
solar trickle charger and alternator wingdood Fuel Economy Forum 33 10-12-2009 04:02 PM
