View Poll Results: Do you believe Toyota is an Honorable Company ?
yes 42 89.36%
no 6 12.77%
Multiple Choice Poll. Voters: 47. You may not vote on this poll
Old 06-24-2010, 07:42 PM   #19
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
I'm pretty sure the response to your poll speaks for it self.
"We have discovered a defect that Toyota has been aware of since Nov 2007.". Umm, this TSB was made public by Toyota close to 3 years ago, anybody that has taken a moment to look up TSB's has discovered it. It was posted on this site since at least Oct 2008 (Last time the post was edited). You've been a member here since 2008... I think you can see where I'm going with this.
If you're upset that it isn't covered on cars that are out of warranty, it really is unfortunate. Maybe in the future, you might want to check the Service Bulletins while your car is still under warranty. Don't wait for, or expect, the manufacturer to send you a notice.
While it is easier to blame Toyota, not looking sure isn't going to save you any money. Looking up TSB's takes a lot less effort than to "picket a Toyota dealership", I doubt you'll do either.
On a side note, with the recent activity of an ex-member whose name we shall not speak.... are we being trolled here?
Stove is offline
Old 06-24-2010, 09:17 PM   #20
rslyk
Drives: 2007 YARIS 3 DR HATCHBACK
You are absolutely correct..... It is my fault that Toyota manufactured a defective
car and choses to not own up to it.... I did not bother to do anything other than
trust Toyota. My mistake, it won't happen again. I think you are missing the point....Why are you not championing an effort to let all Yaris owners know that if your vin is #xxxxxxxxx75126293 and below this problem sooner or later will bite you. You claim to be an all knowing Yaris owner who just happens to have a car that this defect does not apply. I'll bet that if you witness a rape.... if it is not YOUR daughter....she must have had it coming. I have experienced this kind of appathy and denial too many times in the past....when Ford told me that the misterious unintended accelleration of my Ford LTD didn't exsist... a recall followed ....when two different sets of my Firestone tires delaminated, one causing a roll over, they said it had never happened to anyone else before....a recall followed.... When a Force outboard motor broke off and jumped up into the boat with us, Brunswick said that was impossible...a recall followed...When my neighbors Toyota accelerated out of control.....Toyta claimed it was his fault... a recall has followed....what is the common thread ?.....in each case the manufacturer refused to acknowledge a defect untill the liability was to big to deny and the cost of ignoring it rose to a value greater than sending out a TSB and hoping the clock runs out. This defect will not kill anyone but is a unresolved defect none the less...When this failure happens, Toyota will sell $1000 worth of parts each time it occurs. I am really glad that YOUR Toyota is not affected....You are right the Poll says it all.
rslyk is offline
Old 06-24-2010, 09:27 PM   #21
Billiam
Drives: '10 White Yaris 4D LB
Like it or not...recalls are issued concerning safety issues. TSBs are issued for issues that may effect some vehicles, but not all and are rarely safety related. All vehicles, by all manufacturers have TSBs.
Billiam is offline
Old 06-24-2010, 09:28 PM   #22
man, you and your friends have bad luck w/ cars!
im not saying toyota is without fault, my 04 matrix xrs has plenty of problems with it.
instead of a rogue engine code, why not go after toyota's shitty paint that chips if you look at it funny. or how the 1zzfe transmission suck and usually wear out by 150000kms. or how the 2zz 6spd clutch in 03/04 matrixs prematurely wears out....
you seem to be barking up the wrong tree with your crusade on this site, it seems.
good luck rslyk, you're going to need it.
thebarber is offline
Old 06-24-2010, 09:44 PM   #23
MadMax
MadMax's Avatar
Originally Posted by rslyk View Post
Mad Max....I can see that customer satisfaction must truely be practiced in your business..sell defective products and some how make believe that it is OK because
everyine else does it.....If you don't like my spelling.......I don't challenge your
integrity you have already demonstrated it clearly.
My "business" for almost the past 30 years has been providing national security so dumbasses like you can spout their stupid opinions freely.
Obviously you must be a "satisfied customer," because you have the ability to spew such nonsense without someone cracking your ignorant skull in!
You're welcome!
Now go away, troll; you're giving Texas a bad name!
MadMax is offline
Old 06-24-2010, 09:45 PM   #24
sickpuppy1
Drives: 2010 Yaris Sedan
I can see a recall if it is safety related, or will affect a large percentage of vehicles. If it is something that will effect only a small percentage in only certain situations then a recall is not called for. They did not knowingly build them like this, but found out afterward,and corrected as an ongoing build modification,and issued the TSB for the rest,so integrity is intact as I see it. If they knew it and continued to build it like that anyways, that would be another issue.
With your luck in vehicles, I was going to suggest the bus line, but I dont think they have seatbelts and no airbags for sure. But then again, you'd probably get strangled by the belt or a black eye from the bag so......good luck and watch your back,there out to get you!! lol
sickpuppy1 is offline
Old 06-24-2010, 09:49 PM   #25
sickpuppy1
And by the way,THANK YOU MAX !!!!
Old 06-24-2010, 10:39 PM   #26
Stove
Stove's Avatar
This supports your argument how? If you want to discuss how and when people might report a crime, I would suggest the "Off-Topic" section of this forum.
I was looking for the Ford recall and I can't find a recall notice for any year of the Ford LTD regarding unintended acceleration, what year was your LTD?
My Yaris isn't my first car, it isn't even my 10th. I've had cars that had recalls issued against them and a few Service Bulletins as well. My current car will probably have a few Service Bulletins issued against it within the next year or two and I'll watch for them. It has already had one recall. It's over a vehicle capacity sticker, a B.S. recall in my opinion but it's still a recall. I don't assume it's everyone else's responsibility to keep me informed about things I own, nor do I wait until my warranty is up to "discover" the things I should have had serviced.
Recall does not equal Service Bulletin, you aren't going to see a recall on your current issue.
Stove is offline
Old 06-24-2010, 10:45 PM   #27
tomato
tomato's Avatar
Stove, ^ you beat me to it.
I was wondering how we got from Toyota to rapes?!!
OP, you know this is an Toyota Yaris enthusiasts' forum, right?
You asked an ethical / highly subjective question "is Toyota honorable?" I think you got your answer in the poll, loud and clear. It's not apathy, it's how we feel!
The rest of your argument is debatable, but don't feel too bad if you're not getting the response you expect from this board. You do know this is an "enthusiasts' board," right?
Now if you had mentioned the paint, I think you might have gotten a completely different response from this board
By the way, everybody takes a deep breath in here , yeah you too, Max
tomato is offline
Old 06-24-2010, 10:56 PM   #28
tomato
tomato's Avatar
PS. The Yaris is the very first car I buy with a little bit of manufacturer's warranty on it. Most of the cars I've driven had no warranty. Some of the cars I bought were way older than me (back in my younger days) and some were probably unsafe to drive by today's standards (come to think of it, by yesterday's standards, too). Maybe that's why I'm not too worried about my Yaris.
tomato is offline
Old 06-25-2010, 12:04 AM   #29
MadMax
MadMax's Avatar
Oh, I'm breathing fine! I learned long ago not to allow idiots--especially on the Internet--to get me all worked up.
But I also don't take insults lightly, especially when it comes to my integrity.
And being that the OP is from the great state of Texas, he should know better; as those are what are termed as "fighting words" in this state. But I have a pretty good idea of what kind of individual we are talking about here. He doesn't have anything to offer on this forum, and I honestly don't expect him to be on here too long...
Oh, and thanks sickpuppy1; I appreciate the kind words!
Cheers! M2
MadMax is offline
Old 06-25-2010, 02:23 AM   #30
Mad Goon
New To The Import Thing..
Mad Goon's Avatar
Drives: 07 Yaris 71 Comet 69 Maverick
Send a message via AIM to Mad Goon
Meh, "honor" is something that's hard to come by these days. I don't think ANY company can say they practice "honorable" procedures...
Do I think Toyota makes good cars? Of course I do. I wouldn't have taken the time to register on a Toyota Yaris message board if I didn't.
Last edited by Mad Goon; 06-25-2010 at 02:24 AM. Reason: Had 2 chili burritos and had to run to the bathroom so I hit enter to "save" my post.
Mad Goon is offline
Old 06-25-2010, 09:09 AM   #31
rslyk
The barber.....I certainly agree with you it is an uphill climb.....but if one Yaris owner
with this defect can avoid a $1000 parts purchase it worth the abuse....I see by
your profile you own an 07 hatch back..down load Tsb #eg048-07 ....if it applies to
your car spend the $25 on parts before it fails....
rslyk is offline
Old 06-25-2010, 01:57 PM   #32
rslyk
Stove...The Ford recall was on the cruise control that would for no reason
go to wide open throtle....it was in the mid 80's and was phantom problem
that took Ford years to live up to...I believe it was finally linked to a ground
path problem....
rslyk is offline
Old 06-25-2010, 02:04 PM   #33
if it fails, so be it. likely be exasperated by the supercharger im puting on.
if it dies and i cant get warranty to replace it, ill buy a used 1nzfe and put it in myself, or try my hand at installing a 2zrfe...any tsb's on that engine?
Old 06-25-2010, 02:04 PM   #34
rslyk
Sickpuppy....I don't believe that there has been anywhere I have called for a recall..
my point is that if you own one of these defective vehicles and it has not failed yet..
spend the $25 for the redesigned part and avoid the $1000 purchase of the part it will cause to fail...
rslyk is offline
Old 06-25-2010, 02:06 PM   #35
rslyk
Rock on.....I like you style.
rslyk is offline
Old 06-25-2010, 02:25 PM   #36
127.0.0.1
path problem....
you sure this is not the multi-million vehicle recall where fords caught fire because the cruise control brake switch was in the brake fluid and vehicle would catch fire overnight in the garage ?
or any of the other of millions of recalls by 'name ANY auto manufacturer here' ?
to rslyk
yeah it sucks to have a problem with a car, but the way you're talking about it, the way you are doing, and bringing up completely irrelevant comparisons, is only making you look foolish here...
Toyota is a corporation, and the goal is to 'make money for stockholders'. Period. To achieve that goal, they strive to design reliable and stylish automobiles (and other heavy machinery and products) for various price points. Failures detract from that goal. Mistakes can and will happen and Toyota tries to correct them. Your expectations as stated are unreasonable and quite silly, and don't 'float' in the real world.
sh*t happens, deal with it.
127.0.0.1 is offline
2007 Toyota Yaris Hatchback - 5-Speed Manual truebreakerz Cars for Sale by private party 23 09-17-2009 09:29 PM
New Toyota Yaris jaspie Australia 6 11-05-2008 09:23 PM
