Old 06-28-2010, 01:26 AM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-28-2010, 01:26 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Anytime. Tomorrow I'll finish the other kickpod up AND seal up the original pod. I'm hearing tighter response from the sealed pod. I'll also mess with some wiring that is causing some panels to flex. I MAY, depending on time, get the sub enclosure working. If not tomorrow, it should be by Saturday. After that enclosure goes in, I'll be taking the long arduous steps of making panels, finishing the pillars and pods, and making the wiring all pretty. That will probably take a month. After that it's seat time. I can't wait to get this thing under the Auto EQ and Auto TA functions. I've got some massive glare in some upper frequencies. It's enough to make you cringe...even as off axis as I have those tweeters. Again, EQing and perhaps a dash mat will help that.
I can't imagine what these L1 Pro SEs would do on axis. I'd say just under the level of horn's abilities to make your ears bleed. There's just NO need for me to play them on axis, they've got GREAT sparkle at 45 degrees.
I've got a busy week. Testing for Yamhill County, interviews...
Good luck with the testing/interview process, I start next Tuesday.
I'm not surprised to hear you decided to go sealed, the tightness offered by sealing a midbass is awesome. I think there really are only two reasons why somebody shouldn't seal up a midbass...
1) The driver can't play the low stuff with much authority and needs the help of an IB enclosure
2) To make a sealed enclosure is just too much work in the given space/install.
You should also gain a bit of efficiency I'd think by going sealed, tho you will also get a slightly quicker rolloff (which doesn't matter cause you have a sub).
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
Micro Image underpanel install DIY cali yaris DIY / Maintenance / Service 27 08-29-2009 09:48 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
where can i install these power locks? songa New England 1 12-04-2008 12:41 PM
