Old 11-09-2010, 01:10 PM   #1
rognewton
welshdodger
rognewton's Avatar
Drives: toyoto yaris
Multimedia Player
Hi to you all at Toyoto yaris forum
This is my second time i tried to upload this info
the first time seems to dissappered
I have bought a Multimedia Player like the one's you all shown
I read the 16 pages on how to replace a works radio with the Multimedia Player, and with your great pic's i can see how to remove the unit and replace it with mine.
The question i have is there,s no pic's of the back of the radio comming out
with all the plugs
On my Multimedia Player unit i have a load of female Phono plugs for speakers,
Is there a load of male Phono plugs ready on the yaris for me to plug into,
or do i use them at all.
i going to uplload pic's of my Multimedia Player unit
any help with please
thanks
rognewton
rognewton is offline   Reply With Quote
Old 11-09-2010, 01:33 PM   #2
rognewton
welshdodger
rognewton's Avatar
Multimedia Player
Hello all at toyota yaris forums
I cant work out how to add Pic,s to my Post
i have managed to add Pic' to attachments
i dont know this will work
if any one can help
thanks
rognewton
Old 12-07-2010, 08:40 AM   #3
brendan
brendan's Avatar
Drives: toyota yaris
if any one can help
thanks
rognewton
Attachment 38154
Attachment 38155
Attachment 38156
Attachment 38157
Attachment 38158
Attachment 38159
Attachment 38154
Attachment 38155
Where did you buy yours and for how much? are you still happy with it?
thanks
brendan
brendan is offline   Reply With Quote
Old 11-09-2010, 03:18 PM   #4
Your standard speaker connections are made through the two wiring harnesses that are wrapped in foam. These will (should) just plug straight into the existing harness behind your dash.
All the other 'stuff' is for external devices such as DVD screens, backup cameras, iPods, etc. The grey and black extra speaker wires are probably of no concern to you at this time.
Hope that helps you out some.
Old 11-09-2010, 04:38 PM   #5
rognewton
welshdodger
rognewton's Avatar
Thanks WeeYari,
I been puting off fiting this unit, just in case i messed up
thanks for your advice
rognewton
Old 11-13-2010, 03:44 PM   #6
rognewton
welshdodger
rognewton's Avatar
Multimedia Player
hello all
Thanks WeeYari for your advice.
I Need more advice
I have started to swap my unit only to find thad the aerial lead has a recancle box with 2 wires attached wihch fits into the back of my radio not the standed round plug.
The 2 two leads come from the same trunking one which is a small coaxal lead standed areial lead, the other thiner finer black lead thats attached to the recancle box to seprate pin
Any help with this please
rognewton
Old 11-13-2010, 05:17 PM   #7
enve1160
Drives: yaris
Can u post a pic of what your having issues with. Im having a hard time understanding.
enve1160 is offline   Reply With Quote
Old 11-13-2010, 08:45 PM   #8
hello all
I Need more advice
rognewton
This car has a power amplified antenna, and I believe you are referring to the wire that supplies the power. There is a blue wire in the harness that connects to this antenna power lead.
I really do hope this is what you are talking about. If not, post up quick.
Old 11-14-2010, 01:54 PM   #9
rognewton
welshdodger
rognewton's Avatar
Multimedia Player
Thanks for advice,
i am going to upload pic,s of the aerial plug plus the back of the radio that came with the car
I think your right WeeYari that the other small black cable is for the power antenna
When i tested the aerial out on my new unit the radio worked,but the EJECT on the CD PLAYER and STEERING COULUM controls did not work on the new unit.
Replaced my old radio and EJECT and STEERING COULUM worked.
Before i join the black lead to the blue POWER ANTENNA lead in the harness will there be problems like my new unit blowing up [/COLOR]
I will email my supplier for help as well
thanks to you all for your help
Old 11-13-2010, 03:17 AM   #10
enve1160
Drives: yaris
So I installed my gps that i bought from ebay. Hooked it up to my 4 channel amp with infinity reference speakers. I am very impressed with the sound quality. No static/ engine noise. Very clean signal coming out of the RCA's. Now after a week of messing with it I found a few flaws with my unit.
First, I cant get the color of the knobs / LEDs to change to any color. They are all red. I need them to be green. The option for changing color does not let me change it. I dont know if any other settings are not letting this to enable the led color change.
Second, the radio reception is bad. Picks up alot of static.
Third, DVD player seems to freeze at random times for no more than 5 seconds. Im not sure if its because of bumps on the road or what. I also sat on my driveway to watch a movie and notice it doing the same thing, but it seemed like it would freeze for a couple seconds when it changed chapters.
Other than what i mentioned everything else works great. The only thing I havnt messed with is the ipod connection.
By the way I had to edit this post. I mentioned that the music from the sdcard sound harsh and overpowering, well it turned out the dvd gain controls the sd card gain.
Old 11-14-2010, 05:30 PM   #11
amanda_84
Drives: 2010 Toyota Yaris YR
Send a message via MSN to amanda_84
Try turning you car lights on....I did this and then the other lights came on and I was able to change the colours...
amanda_84 is offline   Reply With Quote
Old 11-16-2010, 02:22 PM   #12
rognewton
welshdodger
rognewton's Avatar
Multimedia Player
Hi all at the Yaris Forums
Still need help with the new Multimedia Player. I have uploaded pictures of the new aerial system for yaris 2010
can any body confirm that the small black wire attached
to the new recangle box next to the coaxed aerial
is a power antenna wire
and can i join this to my harness power antenna blue wire
When i tested the new Multimedia Player without this wire i could not
get my CD PLAYER to eject or my stearing wheel controls to work on the new
Multimedia Player
So for now i replaced my works radio
As i dont wont to blow my new unit if i wrong
hope some one can help
thanks to those who have
rognewton
Old 11-16-2010, 03:18 PM   #13
1 - Yes, the black wire will be the antenna power.
2 - Does this unit say it actually supports steering wheel control? I don't see any connectors for steering controls.
3 - Don't know what to say about your CD eject issue.
Also, I think you should start your own thread. Your head unit is not the same as the one featured in this thread, and you've got your own unique circumstances to address.
Old 11-16-2010, 09:53 PM   #14
sickpuppy1
Drives: 2010 Yaris Sedan
Didnt someone else have a thread about this? European antenna being different than the US? Could be wrong. Where is CT Scot when ya need him,LOL
Old 11-17-2010, 07:56 AM   #15
^ I think you may be thinking of a thread in which the OP had a similar question. It was European yes, but the vehicle involved was a 1st gen Yaris with a non-amplified antenna.
http://www.yarisworld.com/forums/sho...16&postcount=9
Old 11-17-2010, 02:22 PM   #16
rognewton
welshdodger
rognewton's Avatar
Multimedia Player
Thanks WeeYari for your advice again,
and others from the Forum
Yes you are probably right about the power antenna
I have had a reply from the people who supplied the unit
asking me to sent pictures and give details of the proplems
If i get some real answers off them, and manage to fix, and get the unit to work propley
I will set up a full how to with pic's on the forum
other wise, i will sell it on
thanks all for your help
rognewton
Old 11-18-2010, 04:07 PM   #17
frannis
Drives: '09 Yaris Sedan
can i get a link to where i can order the HU?
frannis is offline   Reply With Quote
Old 11-19-2010, 08:04 AM   #18
I realize there are a lot of posts in this thread, but there are already numerous links to ebay providers in here.
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Decent eBay deal on harness and double DIN kit Sodium Duck In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2009 12:04 AM
