![]() ![]() Drives: 06' Yaris 1.3l Join Date: Jul 2014
Hi there,
I've purchased a similar unit but have problems installing the unit. (I've installed a single din headunit into my yaris before). The problem I have is that on the factory mounting brackets the came with the yaris there are "dimples" on the mount which were used to hold onto the factory unit.. However the Headunit I have purchased does not have those holes.., So what's happened now is when I screw the bracket on, those "dimples" are causing the bracket to not sit flush and instead stick out a bit and now I am unable to install this headunit.. Can anyone help? |
![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
Well the bluetooth died on this unit. The unit that the thread is talking about that everyone bought. Anyone else have this problem?
It has ceased to function entirely. And of course, no indication on the screen of what may have gone wrong. Tried several different phones, so its not the phone. |
![]() Drives: Yaris hachback 2011 Join Date: Jun 2014
2 Din new navigation radio system
Hello All,
Sorry for my previous post where the picture were not public :-( I'm looking to change the factory radio of my 2011 Yaris Hatchback 4 doors (Canadian model) for a new navigation radio system. l'm worry if it will fit whit my current radio trim. See images below. The new navigation system that I'm looking for: ![]() My actual radio see trim detail: ![]() Other Yaris radio model (sedan or newer?) trim where radio side button goes under the trim. ![]() What do you thing? Thank you in advance! |
Y4R1Z
Judging from the pics I would say that model is not going to fit in a hatchback yaris.
Modded Moderator
I disagree. Looks like it may fit fine as it replaces not just the stereo but also replaces some of the plastic surrounding. The other yaris is a European version and I'm sure if needed you can order the trim and it snaps in.
#6 | |
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
See CTScott's comparison pic: ![]() Above, regular double DIN sized radio and surround bezel, below, the kinda double DIN sized looking factory radio. I still haven't figured out in which market the silver "integrated" head unit was sold. Has to be Europe, because manual with tach, and electronic A/C controls. |
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
I want this eBay Android Unit but wondered if anyone had any experience with these kinds of things? Was going to go the Nexus 7 route again but figured if these are already all set up and better... and I would really like a back up camera.
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
#8 | |
Think Im just going to do the Nexus 7 install again, heh.
Has anyone else had the bluetooth die? And what did you do?
Just get a new, separate bluetooth system? |
![]() Drives: 2010 Yaris Join Date: Mar 2016
Going to revive this... because i think i want one of the updated units.
is everyone still happy ? |
2010EGGHATCH
Drives: White 2010 Yaris Hatch Join Date: Apr 2016
I had mine for less than a year. The Bluetooth stops working once radio warms up and gets fuzzy like there's no signal until you restart the unit. Finally a few weeks ago the whole unit just died it will go to DVD mode randomly whenever it wants then fail because there's no disc inside and this will repeat over and over. I'd never recommend anyone to purchase this radio and for the price you can get way better.
Sent from my SM-G920T using Tapatalk
IG: 2010EGGHATCH |
I ended up installing a joying 7" LCD unit this weekend, so, we will see how that works out
...aaannnnd it's going to go back. Equalizer doesn't work, radio reception is poor on some stations. I also cant get around 18 presets, no more, no less. Also the screen protector is leaking off and bubling, and I can't remove it because it's under the bezel.
Oh and it's 103mm vs 100 so I can't quuiiiite get it to fit under trim |
Drives: 2009 Yaris 4 door sedan Join Date: Jun 2016
Joying bluetooth receiver
Hi,
I am looking to install this in my 2009 4 door yaris: JOYING 7" Latest Android 5.1 Lollipop Double 2 Din Car Stereo Quad Core 1024*600 Head Unit Bluetooth Touch Screen GPS AM/FM Radio Receiver Support Steering Wheel/Backup Camera/4g/WiFi/1080p Anyone else tried this unit ? Any issues ? Thanks ! Gary |
Yes. It sucks. I had a very similar model an it was a bitch to upgrade / use and the screen was pealing.
Sent it back
2010 hatchback Fog lights, Kenwood touchscreen, backup camera |
To expand on this:
Navigation sucked, the included app would always lock up, and I never got a reliable usage of google maps, and I would just use my phone in any case. After a firmware update to fix an issue I had with Bluetooth, the dimmer function no longer worked with my headlights, and in fact was removed from settings entirely. The antenna connector,as well as the microphone interface, was very poor. And I got crap quality. The radio tuner app was poorly designed. I think you are also unable to just get another one because it's baked in The internet is rife with similar reviews and even fixes involving cutting traces and adding solder I am convinced all glowing reviews are fake or special units getting the best qc Honestly avoid it. Same goes with all of them, joyig, pumpkin, etc.
Well I can say that I didn't have most of the problems that you later guys are complaining of. But the bluetooth function on mine is completely dead.
We all already knew this really isn't the highest quality unit out there, although don't get me wrong, I'm not defending it. But when you've got $800 and $1200 units available from reputable brand names such as pioneer and a couple others, I can't say that I'm real surprised to see that the quality control on these units wasn't up to par. Can anyone recommend one of these types of units that's really high quality? One where you can actually scroll fast through an audiobook or radio show that you've put on a USB flash drive, and inserted into the USB port to listen to on the radio in the car. And it would be really nice to be able to delete stuff off of the flash drive, from the screen. Also that has a good GPS program and bluetooth that actually freakin' works. Anyone know of a unit like that? Last edited by BennyLava; 08-19-2016 at 04:56 AM. |
| ACRONYM thread | Shroomster | Off-topic / Other Cars / Everything else Discussions | 45 | 02-15-2025 10:30 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Used Kenwood 7037 Double Din Touch Screen +10 Disc Changer ! | micquek | Items for Sale by private party | 0 | 12-31-2009 08:31 AM |
| Getting ready to get a DOUBLE DIN touch screen player, NEED INPUT! | Syroyizhka | General Yaris / Vitz Discussion | 12 | 04-08-2009 10:26 PM |
| Decent eBay deal on harness and double DIN kit | Sodium Duck | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2009 12:04 AM |
