![]() ![]() Drives: Yaris sedan Join Date: Jun 2010
I have been using 5w-30, it indicates 5w-30 on the oil cap and recommends 5w-30 on my manual. I don't think everyone needs synthetic oil though, if you drive mostly on the highways, conventional oil should be fine.
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
[QUOTE=Ryude;489025]Toyota recently released a press note saying that over the next year they will start to recommend 0w-20 synthetic oil across several models, due to lower emissions and higher efficiency. I wonder if the yaris will be one of them?[/QUOTE
They can recommend all they want!...my manuel and oil cap states 5w-30 and thats exactly what will go into the little dude!.Sounds as if the illusterious EPA is at it again with their rediculous standards.0w-20,please....more efficient,less emissions ![]() ![]() !.Gee,all that crap THEY have been mandating for decades apparently isn't working if we still have "problems".They should be putting regs on Volcanos,their private jets etc,etc,etc,![]() ![]() ![]()
2008 YARIS sedan : 3 qts. and 22 ounces of SHELL conventional and new TOYO oil filter on 7/03 . Decided to pour the used oil from the pan and oil filter into empty 4 quart oil jug . There was little over 3 quarts in it . Figure around 3/4 quart of oil remains in the engine .
#4 | |
Drives: 07 sedan Join Date: Mar 2010
2010 3 door : 3 qts. + 22 ounces SHELL 5w-30 dino and new TOYO oil filter on 7/04 .
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
Mobile 1 full synthetic 5w30 and a genuine Toyota filter. Oh and I get 2 filters for $10
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Mobil1 5W-30 Extended Performance and a K&N Gold oil filter for another 15k mile drain interval. Nothing on the magnetic drain plug.
Also changed the transmission fluid for the 2nd time, again with Redline MT-90. Good for another 50k miles.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
hey, if toyota can recommend 0w-20, i don't see anything wrong with putting it in my yaris. if there's an added benefit for fuel economy and emissions, so be it. that's what i'm going to be using.
we picked up 4 TOYOTA ( Denso ) oil filters at $3.50 each excluding tax . Didn't give us free washers this time
Tw200--excellent!
Don't believe everything they print 1812.....it isn't beneficial to your engine.
#13 | |
http://inlinethumb62.webshots.com/43...600x600Q85.jpg from the picture i provided above, my plug looks like that except without that silver washer... |
yes , there's a washer needed for a better seal and easier removal of the drain plug . There are plastic and paper like washers available . I've been using the pressed paper washers . Can be used a few times .
| preformance air filter and oil change? | JapRulezz | DIY / Maintenance / Service | 10 | 12-14-2009 08:24 AM |
| service maintance light | io3 | Yaris TS Talk | 11 | 09-22-2009 03:03 PM |
| Oil change time intervals | PaidTimeOff | DIY / Maintenance / Service | 17 | 01-29-2009 07:14 PM |
| How often do I need to change my synthetic oil? | hans_fh | DIY / Maintenance / Service | 21 | 08-20-2007 05:08 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
