Old 06-28-2010, 10:17 PM   #1
Originally Posted by sex View Post
Thanks Scott. So much for the 07 EWD...
The plan is to tap into this wire and add a toggle switch, which will drive a relay. That relay will be used switch a new line to feed a pair of horns.
This way I keep the stock horn for friendly beeps and use the louder ones with discretion.
That's a bear to get at, as it requires having the dash off. I would switch on the control side instead. You can cut into the wire that goes to the horn switch, which is way more accessible on the bottom of the steering column.
DIY - How to remove or insert a pin on the ECM Connector A21 CTScott DIY / Maintenance / Service 6 05-21-2024 12:29 PM
YARIS/VITZ 2006 - USB Connector on Dashboard or Console jojozep2008 In Car Entertainment + Electronics (audio / video / alarm) 8 04-19-2011 11:41 AM
What is that connector for? (in the door) kac DIY / Maintenance / Service 2 05-20-2010 05:03 PM
Scanguage II connector pins defect?? auxmike DIY / Maintenance / Service 21 09-14-2009 11:59 PM
AUX connector for Yaris 2006 quemaculo In Car Entertainment + Electronics (audio / video / alarm) 1 08-27-2006 09:14 PM
