Old 06-29-2010, 06:56 PM   #1
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
You know that thing has the actual miles of the original car that it was on and it will not read yours ( miles) unless you take it to a dealer with the right tools. Other then that its awsome having the tac.
What would I need to adjust the mileage? I saw a USDM cluster w/ tach on ebay awhile back for $50 and I would have gotten it, but the mileage was off and I was told by a Toyota mechanic that it wasn't going to be as easy as it sounds...
Old 06-29-2010, 08:02 PM   #2
Changing the mileage requires reprogramming a EEPROM IC on the cluster. It can't be done using the Toyota Techstream service tool, so most dealerships order replacement tachs with the mileage pre-programmed for the car that it is going into. There are speedometer repair shops that have the necessary equipment to do the programming.
Old 06-29-2010, 08:34 PM   #3
cdydjded
Drives: Yaris LB Turbo
It has to be from a Hatchback, if not it will not work. Toyota mechanics as smart & well trained as they are will always say it work work until they try it.
cdydjded is offline   Reply With Quote
Mind Blowing Email I received *MAD DOG* Off-topic / Other Cars / Everything else Discussions 19 06-14-2010 10:26 PM
Received Header & Exhaust..Install Soon AlainMikli Performance Modifications 16 04-25-2009 11:42 PM
Anyone received a call for a survey? YarisFan007 California 1 02-15-2009 12:40 PM
I received my new rims today, now... REM Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 02-13-2009 10:57 PM
Package received from Taiwan! GabL Cosmetic Modifications (Exterior/Interior) 74 09-25-2007 09:37 AM
