#1 | |
![]() ![]() ![]() Drives: 05 YRS Silver Lining Metallic Join Date: Jan 2006
Yes. The original wiring was insufficient to set up properly. You'd probably need about several meters of wire: - about 1.5 meters for the thick black 12v wire connecting to the + battery terminal - about 2 meters for the thick red 12v wire connecting to the fog lights - about 2 meters for the thick red switched 12v wire (I used the same thick red ones but you can use thinner ones) to reach the park light wires near the headlight assembly. - about 1 meter of the ribbed tube to cover the wires. Instead of splicing wires, I used connectors and a crimper to make it safe and secure. |
oh and thanks jimcat for the fog lights and thanks violin for the mud guards!
Rwseattle
Drives: 2007 Toyota Yaris (BASE) Join Date: Dec 2006
Great. Thank for the feedback.
Green is good
Drives: 3dr YRS Join Date: Jan 2007
as400g33k, where did you source the +12V parker light wire? Behind the steering column, behind the glovebox, or behind the headlight itself?
Do your fog lights work in all headlight switch positions (i.e. parkers, low beam, high beam)? |
#6 | |
Yes on all. |
Will work for Yaris...
Drives: Yaris Join Date: Feb 2006
Hi just would like to ask where did you get the fog light covers? From toyota dealer or was it included in the package?
Cheers |
yep, its included in the package.
![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
QUESTION:
I have mine installed this way: ![]() I purchased the base for the bulbs but when i removed the bumper i found that the factory harness and plug was already there, followed the cable inside the dash and removed from the plug, connected that cable to a relay and from the relay to a fuse and that to a live line to the battery. The relay is powered by the key switched line and then to a switch. Problem is that the line marked in red in the diagram gets hot. Is this normal or what should i do to prevent this??? Kitt
20 years... alive and kickin'!! ![]()
Low in should be the line that comes from your switch, low out should be ground, 30a in, from your battery and 30a out should go to your fogs... This is a standard type of relay, they usually have a diagram printed on its side, if you could post a picture of it i may help you better
Rwseattle
Pix
My PC is not downloading the relay pix. I'm not sure why. I will downloaden tomorrow at work. The relay does not show any wiring diagram. It only says YLE YL-388-S Automotive relay 12V/40A. I got 4 connectors and they're all the same size. I will post pix tomorrow. Thanks for your help.
It should have something like this...
![]() post the picture anyways and i'll see what i can do
Rwseattle
Here's the pic
Hopefully this helps.
#14 |
ummmm not that much tough... you will need a continuity tester then to find it out. The 2 connectors that have continuity are ones that will go to the switch and to the ground, the other two ones will come from the fuse to the fog lights...
and try to post a bigger picture to see if it helps, focused on the pins of the relay
#15 |
Shiny Chromey Coolness
Drives: 2007 Toyota Yaris Liftback Join Date: Feb 2007
Foglights installed and functional...the best mod for me yet!!!
Bringin the Bling to Yarisworld |
#16 |
Rwseattle
Thank you.
I found the correct connection. I did use the continuity tester. I will post pictures of working fog lights soon. I'm installing a front strut bar and will post pictures all together. Thank you for your help.
#17 |
Rwseattle
Here a pic of wrk foglights.
#18 |
Green is good
| Ebay OEM style fog lights installed | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 29 | 04-28-2009 10:14 AM |
| EBAY OEM BUMPER FOG LIGHTS | Wayside | General Yaris / Vitz Discussion | 41 | 01-09-2007 12:52 AM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| "OEM" fog lights from ebay | drell42 | Cosmetic Modifications (Exterior/Interior) | 5 | 07-28-2006 09:21 AM |
| Liftback Fog Lights on eBay | Chris07LB | General Yaris / Vitz Discussion | 8 | 07-24-2006 07:06 AM |
