#37 | |
black shark
Drives: black toyota yaris t3 sprit Join Date: May 2010
ok here is what u can do, try and find a heads up display that also gives u your fuel guage on it, then u can keep your eyes on the road and on everything else like your speed, gas, car temp, if not u will need to try and look at the dash, becoz when your car's temp goes up for what ever reason, you are going to blow your engine, and that would be worst then running out of gas, sometimes the distance u travel might change, if u drive or get stuck in traffic
www.justbabynappies.co.za |
#38 |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
ask CTScott to wire a 20,000 volt shock to your arse when the last bar blinks
#39 |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
Create a direct link from the ECU to your cerebellum, preferably wirelessly. This will provide continuous real time updates.
#40 |
The Gauge Cluster tells you more than gas... If you're not checking it at least every 30 seconds..... you're wrong.
#41 | |
![]() ![]() Drives: 2008 Yaris LB 5 speed Join Date: Oct 2008
#42 |
![]() ![]() Drives: 07 5 door Hatchback Join Date: Jul 2007
You are supposed to scan all 3 mirrors and gauges every few minutes.
#43 |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
No offense, OP, but I think it's nearly impossible to run out of gas, especially in a Yaris (or other gas sipper). I don't constantly monitor my gas, but the flashing gas bar is very noticeable. 30+ miles to go when it's flashing is plenty of gas to find a gas station.
On a side note, I once had to drive home (about 30 miles) on a rapidly flashing bar, because payday was the next day. I drafted a semi at 55-60mph all the way home and still had gas the next day to get to the station... I love my Yaris
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
#44 |
Geek
Drives: 2007 Red 3-Door Join Date: May 2010
Yea, it took a little time to get used to but I would always catch it just as the bar started blinking. The first time was harrowing until I realized that the blinking did mean I was low but usually I had around 12-15 miles left of fuel which was usually more than enough to find a gas station. These days I usually don't let it get lower than 2 bars.
#45 |
3,300+ at one point.. >:(
Drives: 2010 Hatchback RS Join Date: Aug 2007
+1. Most times I'm checking even more frequently than 30 seconds.
#46 |
![]() ![]() Drives: 2010 Yaris 5-Door LB AT MM Join Date: Jun 2010
Maybe buy spare Walmart fuel tank.
As for the OP, if worst comes to worst, have a spare fuel tank in the trunk, like this http://www.walmart.com/ip/6-Gallon-F...Gauge/11071221 . But seriously though, lol its a gauge, you're being told how much gas is left, and it actively blinks when it's low. I don't think any car tells you how much miles you have left, that's impossible, because that is really dependent on how fast you drive/driving conditions. It would seriously be a palm face fail moment if Toyota has to recall the Yaris because people can't read what is essentially a bar graph.
#47 |
everyone has good points but not gonna lie, i kinda have to agree with the OP. i have never run out and i prob never will.
the problem i find is ill look at the gas level and it will say 2 bars, then say a min or 2 later ill look back and it will be flashing, i personally think they should have put 10 bars or more in but its something to get use to now on the other hand if u dont notice it flashing and flashing quickly for about 50km (thats usually how far i go on the flash) wtf were u looking at for that aprox hour on the highway? lol
#48 |
ヴィッツ ドライバー
Drives: 2006 3d 1.0 Linea Sol Join Date: Aug 2007
My Yaris does. It takes the average mileage for that tank and approximately calculates how far you could go with the said mileage. However, it's cautious, so when it reaches 0, you actually have some 20-30 miles to go.
#49 |
WCOAST CANADIAN DRIVER!!!
Drives: 2010 Hatch 5DR - AUTO/AC Join Date: Jun 2010
I usually drive about 450-460 KM'S before I re-fuel my Yaris - so that means I usually buy gas every 2 days - since my commute is about 250 KMS a day. That winds up being at least 50% of what it used to cost me to drive my 09 RAV4 LTD V4 the same distance - I rarely ever watch the fuel gauge - I do watch the KM counter though.
#50 |
lol. never had this problem.
#51 |
Canadetroiter
Me neither.
I guess they could add a warning sound or something once it gets below a certain level, but most people at least check the gauge often enough to keep from running out. Plus one would think that the first time you ran out of gas, it would make you more vigilant in the future. 3 times though is quite a bit.
#52 |
^^ hahahaha...
it should beep for 1 min for each bar the gauge goes down. already people find the seatbelt beeping annoying.. geez. :) |
#53 |
![]() ![]() ![]() Drives: Big Yellow Join Date: May 2009
You could try taping a suggestive photograph of your favorite model next to your gas gauge.
#54 |
Personally - after a month and a few days of owning a Yaris - I've given up staring at the gauges and tracking my gas mileage - I just buy gas every 2 days - usually $10-$15 CDN at a time.
| Sedan better gas mileage than LB? 5 month gas chart included | flint_mica_manual | General Yaris / Vitz Discussion | 24 | 03-09-2009 08:24 AM |
| Anybody run into any other members in your area? | vodkalush | NY / NJ/ CT / PA | 23 | 10-20-2008 11:31 PM |
| Gas question | Meldav86 | General Yaris / Vitz Discussion | 23 | 09-28-2007 06:52 PM |
| Stewart's Gas? | ceres | NY / NJ/ CT / PA | 0 | 11-08-2006 08:08 PM |
| poll concerning gas prices | foober | General Yaris / Vitz Discussion | 15 | 07-24-2006 12:47 AM |
