Old 07-06-2010, 03:32 PM   #1
drunix
Drives: 2010 Yaris 3D LB
How does that little panel pull out? (The "push button start cover".) Is there a trick to it? Thanks. I pulled it part way out and it seems to not want to part company with the panel on the right side.
drunix is offline   Reply With Quote
Old 08-11-2010, 09:38 AM   #2
You have to remove the vertical trim to the right of it first (which you can just pull off with your fingers as well).
Old 09-16-2010, 08:47 PM   #3
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
So in a sedan yaris 2009 you just have to do the switch mount and connect the red wire to the blue one and the black wire(ground) to the brown one of the d3 connector ? Am I right ?
Old 09-17-2010, 07:55 AM   #4
It depends on when in 09 the sedan was built. Some people with 09 sedans have found that the blue wire from the ECM to the steering column is not present. If it is, then the answer to your question is "Yes".
Old 09-17-2010, 11:23 PM   #5
packetrace
packetrace's Avatar
thank you Scott it worked perfectly :D It'S amazingg !!
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
