#2 | |
There are 2 keys to a tug-o-war contest:
#1) Traction is king. A 100hp vehicle with traction can pull a 500hp vehicle around with no traction all day long. Traction is gained by the appropriate tire on a particular surface and the right amount of weight on the drive axle or axles. Typically the more weight the better. Bottom line? Once your wheels are spinning we've got little traction. #2) Torque...particularly low-end torque is much more important than peak horsepower. The Cummins turbo diesel in the Dodge has, not just more torque, but more torque at a lower rpm. That engine generates well in excess of 500 ft lbs of torque at less than 2000 rpm. The 5.7L I-Force is quite an engine, but torque is 401 ft lbs at 3600 rpm. So, if the Dodge as even a small traction advantage (or the traction is even) it will pull the Tundra via it's superior torque. However, under the right circumstances, the Tundra would have no trouble pulling the Ram if it had the traction advantage. Put some very grippy tires on the Tundra (depending on the surface) and a 1000 pounds of ballast in the bed and the outcome may favor the Tundra. At the end of the day, tug-o-war contests don't prove much unless everything except the engines are equal. But they are fun to watch. However, I think we can all agree that the video is clearly a fake. The Tundra would go down scratching and clawing and making a hell of a racket!! Quote:
If you want to enjoy your car, stay off of the internet. Last edited by Billiam; 07-07-2010 at 02:46 PM. |
| What age are people here? Curious what age group is buying this car. | JDE | General Yaris / Vitz Discussion | 351 | 05-19-2011 04:28 PM |
| I've NEVER been more curious to find out! | Syroyizhka | General Yaris / Vitz Discussion | 5 | 04-15-2009 07:35 AM |
| stupid question, but curious | c-one yaris | General Yaris / Vitz Discussion | 1 | 09-28-2007 10:52 AM |
| Just curious | MudBug | Off-topic / Other Cars / Everything else Discussions | 1 | 04-07-2007 06:09 AM |
| Just curious about something | MudBug | Suggestions - Feedback - Questions | 12 | 04-05-2007 10:17 PM |
