Old 07-07-2010, 08:55 PM   #1
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Originally Posted by big lo View Post
Its the battery YT, the dash will light up because it still has a little power, but if you someone to jump start you car to run, then its the battery. You can try this while your car is running take of the positive and disconnect it, if the car shuts off its the alternater, try it and W/B. Now if the car is still running have the battery replaced.
Disconnecting the battery while the car is running is a very bad idea. The battery is the only thing that holds the alternator down somewhere in the vicinity of 12V - disconnect it and it can produce hundreds of volts. You could seriously die. Even if you are lucky and avoid death, there are lots of systems in the Yaris that aren't built for high voltage. You could end up with fried electronics.
Old cars with generators had a current limiter in the voltage regulator, so removing a battery terminal was a common troubleshooting step, oh about half a century ago.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 07-07-2010, 10:07 PM   #2
big lo
big lo's Avatar
Drives: 2007 VIOS
Is that a fact, because I did it to my sedan to check the alternators response because I had a dying battery, and I m still here, with no luck, so before you try to come off as a smarty pants, check the info before posting, in other words dont hate the player hate the game. Do you feel me my dude. This is to learn from one another, no disrespect to anyone so check yourself. Holla.
Old 07-07-2010, 10:44 PM   #3
Sir A.Y. Atoyot
Drives: '08 5-door
Suit yourself - just a warning based on decades of experience in the auto electric field. Ever seen one of those 120 volt converters for car alternators? How do they work? By disconnecting the battery from the alternator.
Just because someone disagrees with something you say doesn't mean he's disrespecting you. Don't be so touchy.
Old 07-07-2010, 10:57 PM   #4
big lo
big lo's Avatar
Drives: 2007 VIOS
Thumbs up
No hard feelings on my part, my bad. I was just letting you know in what I did and nothing happened, but this is not about you or me its YT who needs help, so its water under the bridge, my bad holla my dude.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Problems starting the engine fmicle General Yaris / Vitz Discussion 10 10-07-2009 08:48 AM
Yaris problems (not) fearturtle44 General Yaris / Vitz Discussion 15 01-16-2007 01:49 AM
