Drives: 2007 yaris hatchback Join Date: Jul 2010
I have had my yaris for about 2 years, and i have had no problems with it up until the past few months. if it rains and i haven't driven my car in a few days (i car pool to work), my car will not start!!!!! lately, i have to start it up every single day!!!!! my roomate says it is not the battery because the electrical things on the dashboard will light up and the radio is on. BUT if it isn't the battery why does it start once i've jumped it and let it run for a few minutes?!?!?! HELP!!!!!!!!!!!!!!!!
Its the battery YT, the dash will light up because it still has a little power, but if you someone to jump start you car to run, then its the battery. You can try this while your car is running take of the positive and disconnect it, if the car shuts off its the alternater, try it and W/B. Now if the car is still running have the battery replaced.
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
I suggest pushing the clutch in, then trying to start it.
Edit: In all seriousness though, why don't you turn off all the electrical stuff before you shut your car off? Like the fans, lights, radio, AC, all that stuff. I turn off everything before my car is turned off, just a better idea if you ask me. Last edited by Black_griffin6; 07-05-2010 at 10:35 PM. |
![]() ![]() Drives: 2010 Yaris 5-Door LB AT MM Join Date: Jun 2010
Get a new battery, they're cheap. if you don't drive your car often the battery loses charge, until it can't even start your car anymore. My friend went to the military and asked a friend to routinely start his car for him and drive it around.
![]() ![]() Drives: 2007 Silver 3dr hatch Join Date: Mar 2010
I concur, get a new battery.
Same thing happened to me right after 2 years...I bought the battery for the Tundra from the dealership and conditioned it when I first got it!! Overkill is great!! Good luck and keep us posted
See Pictures of My Yaris at WWW.DusoldEnterprises.com |
And welcome to the forum by the way!
Yaris teacher, are you out there, please let us know on results or anything positive happened with your vehicle.
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
Check the battery connections. Take off the cables and scrape the metal surfaces of the cable ends and the battery posts so you can be sure that the cables are making good contact. There can be corrosion on the surfaces that you can't see. That can degrade the connection just enough to prevent the starter from turning over, but not enough to affect the lights and accessories.
Modded Moderator
Might not hurt to check the fuse box as well. I had a odd headlight problem and it was a blown fuse (someone had put the wrong amp rated fuse in and it blew). but from what your saying sound like something related to the battery or alternator, most likely the battery. If you have an autozone they do free battery testing. I believe walmart still does this too, even if they are a evil empire.
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
If your junpin it and it's a startin...just get a new battery
Least expensive/least time consuming thing to do .
#11 | |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
Old cars with generators had a current limiter in the voltage regulator, so removing a battery terminal was a common troubleshooting step, oh about half a century ago. |
#12 | |
#13 | |
Just because someone disagrees with something you say doesn't mean he's disrespecting you. Don't be so touchy. |
#14 | |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| Problems starting the engine | fmicle | General Yaris / Vitz Discussion | 10 | 10-07-2009 08:48 AM |
| Yaris problems (not) | fearturtle44 | General Yaris / Vitz Discussion | 15 | 01-16-2007 01:49 AM |
