Old 07-08-2010, 05:45 AM   #1
sito
Drives: Toyota
Hi Guys,
I had swapped my 1NZFE chip into the 1ZZFE throttle body but after one day of driving... CEL light up.. error code 0172 (fuel trim too rich bank 1)
I reset my ecu, and drove again... and the next day... the same error code came out....
These two codes came when i was moving off slowly and with air con on.
I swapped the 1ZZFE chip (part number #22030-0D030) back onto the throttle body and there's no CEL till now. But i could feel rpm oscillations when car was slowing down. By adjusting the idling screw, does it helps to remove the oscillations?
Should i stick to 1ZZFE chip or try making the 1NZFE chip works?
Thanks everyone!
sito is offline   Reply With Quote
Old 07-08-2010, 11:01 PM   #2
sito
Drives: Toyota
Any advice, please?
Thanks...
Old 07-09-2010, 01:25 AM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Leave the 1NZ chip in. That's the way I have it and it works great.
Old 07-09-2010, 04:49 AM   #4
sito
Drives: Toyota
Leave the 1ZZ chip in. That's the way I have it and it works great.
Thanks for your advice, tk-421.
Are you using the 1ZZFE chip with the 1ZZFE throttle body too?
Thanks....
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
1ZZ-FE throttle body crxgames Items for Sale by private party 1 04-27-2009 05:19 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 07:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
